Idling problems
Old Dec 5, 2010
bikrchick2000's Avatar
bikrchick2000 is an unknown quantity at this point
Question Idling problems
When I start my 92 Honda civic dx and it warms up it idles up and down what could cause this?
Old Dec 5, 2010
lazlong's Avatar
Re: Idling problems
It only surges during warmup?
Old Dec 5, 2010
Re: Idling problems
yes that is the only time
Old Dec 5, 2010
lazlong's Avatar
Re: Idling problems
Might have air in the cooling system, or a dirty IACV/throttlebody. Could be a vacuum leak but, usually that causes constant high idle.
Old Dec 5, 2010
Re: Idling problems
Thanks for your input,someone told me my idling sensor was going out.
Old Dec 21, 2010
dpcpeoriaserver's Avatar
dpcpeoriaserver is an unknown quantity at this point
Re: Idling problems
check your intake manifold gasket. spray with throttle body cleaner when its warming up. sometimes those get little leaks in them and once they warm up it seals it. if the leak is detected there it will be evident in your idle. your iac will not operate correctly if the gasket is leaky. hence once it warms up, your idle stops surging. this is just one of the things it could be. hope this helps.
Old Feb 28, 2011
grimlock34's Avatar
grimlock34 is an unknown quantity at this point
Re: Idling problems
my 90 dx auto is surging bad too. but its all the time. changed plugs and wires, fuel filter and sprayed some carb cleaner in the carb. worked for a while then surges every now and then when i try to give it gas it boggs down??? any help
Old May 19, 2011
Neil24's Avatar
Neil24 is an unknown quantity at this point
Re: Idling problems
I have the same car with the same problem. Idles high when first started cold. After warmup, idles up and down from 1000 to 3000rpm constantly. If you find a solution, let me know and I will do the same.
Old Jun 26, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
Re: Idling problems
try the idle air control valve or the fast idle thermo valve
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
vtechcivic
Apr 21, 2015 06:58 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
