92 civic , harmonic balancer bolt left or right threaded?
Old Sep 9, 2010
lortech's Avatar
lortech is an unknown quantity at this point
I can recall using the started in the past to loosen these bolts on the harmonic ballancer. Mabey I am wrong? Starter turns the crank counter clockwise so the bolt is held on by a breaker bar and the handle is resting on the left side of the lower control arm. So, is this a regular righty tighty bolt or lefty tighty bolt? One click of the starter did not loosen this bolt.
What is the torqe on these bolts anyway? Used a prybar on ring gear, then use jack to lift up on 1/2 breaker bar. Still could not loosen it.
May have to buy/rent a electric impact gun perferably IR or Snap on. BTW, this is not the Harmonic ballancer that requires the 50 mm hexagon lever stocket.
Poopies
Apr 20, 2017 11:36 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
GH04si
Apr 15, 2015 08:13 PM
ThinkSkin
Nov 2, 2001 10:21 PM
