Honda Help
Old Feb 15, 2010
Bobby Wang's Avatar
Bobby Wang is an unknown quantity at this point
Unhappy Honda Help
Just pulled the head on my 1991 honda civic lx! Dont know much about engines so what should the cylinder block look like on the inside!? should it contain coolant just around the cusbustion cambers! Guy said he could rebuild the head for $120 what does this consist of and will it stop my honda from blowing grayish smoke!? the valvles are very nasty and corroded looking.
Old Feb 15, 2010
Re: Honda Help
any pics? there should be coolant around the engine in those passages, and some may have spilt into the cylinders when the head was removed. if the valves cant be cleaned, it may be worth just replacing em. make sure to check the head for warpage and possibly have it milled flat.
Old Feb 15, 2010
Bobby Wang's Avatar
Re: Honda Help
Thanks for the info.! Piston walls are very clean dont see any damage you think the rings are still good? Thanks for answering my dumb ?'s just tryin to learn as much as I can cuz i really like this damn honda!!
Old Feb 15, 2010
Re: Honda Help
i really cannot say without looking, but that old of an engine, if you are rebuilding it anyway and have smoking problems (or burning oil), its a good idea to replace the piston rings and valve seals.
Old Feb 15, 2010
Bobby Wang's Avatar
Re: Honda Help
Thanks again i got lots more ?'s just not enough time to ask tonite!
Jessica Leung
May 5, 2015 05:12 PM
carid
Apr 30, 2015 07:00 AM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
