1992 Honda Civic DX engine knock
Old Dec 14, 2009
00dude's Avatar
00dude is an unknown quantity at this point
Unhappy 1992 Honda Civic DX engine knock
I have a cold air intake that was right near the passenger front wheel and it sucked up a good amount of water into the engine, lugging it down (the engine) a few times and killed it twice on a long drive home yesterday. Now I've got some blue smoke coming from the exhaust when I start it and a knock to the engine. Spark plug replacement did not affect the knocking. I'm thinking I might have bent a valve because it's a constant metallic knock that speeds up and slows down with the engine. I did a compression test today and got readings of 130, 140, 220 and 185 on cylinders 1-4 respectively.
I included a 1 minute audio segment which can be viewed on youtube.com at:
http://www.youtube.com/watch?v=csTvrlz22t8
I would appreciate any advice on what you think is causing the knock and what it will take to repair. Thank you.
Old Dec 16, 2009
boostnm3's Avatar
boostnm3 is an unknown quantity at this point
Re: 1992 Honda Civic DX engine knock
Have you adjusted your valves lately? Could just be the valves. I know sucking water through the intake isnt a good thing but i honestly dont see how you could have sucked enough to really make a difference unless you drove through a river, lol.
Old Dec 16, 2009
well based on those compression readings, a valve adjustment is the least of his worries. i think you have some major engine rebuild work ahead of you, or look for a used motor and have that swapped in.
Old Dec 16, 2009
boostnm3's Avatar
Standard should be 135-184. The maximum variation between cylinders is 28psi.
Looks like 1 of your cylinders is way out at 220. Do they hold pressure or drop down pretty fast? Well only the first 2 are within each other. The others are way off. The blue smoke you see when you start up is caused by bad valve seals.
Old Dec 17, 2009
TakeN0Prisoners's Avatar
TakeN0Prisoners is an unknown quantity at this point
That sounds like a bad rod knock. Stop running it and open up the engine immediately. This needs to be checked out ASAP.
jessicakaybby
Apr 20, 2015 12:11 PM
ashleymmackey
Apr 18, 2015 09:48 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
bahena08
Apr 11, 2015 05:09 PM
