2000 civic si conversion - parking lights flicker with the ignition and lights off
Old May 2, 2014
MattC1993's Avatar
MattC1993
MattC1993 is an unknown quantity at this point
Question 2000 civic si conversion - parking lights flicker with the ignition and lights off
So I woke up one day last week and I found my left rear marker lense smashed out(baseball bat shaped dent right on corner of light, I was pissed) anyways the bulb also got smashed. It's been fine since then until last night I got home after dark with my girlfriend and my parking lights were dim and flickering, occasionally staying on for a minute or 2. Then I noticed that the marker light above the smashed out turn signal was out while the lights were flickering, mind you my ignition and light switch are both off. Also there is a buzzing sound coming from somewhere around the top of the clutch pedal. So I go inside thinking of why the hell this is happening. I go back outside in a few minutes and the marker light that was out is now back on when the lights flicker. I'm thinking maybe the filament in the broken bulb happened to move and touch the plug or the moisture from all this rain in western massachusetts has something to do with it. I unhooked my battery so my car doesn't burn to the ground. I have no idea what is causing this, hopefully someone has an idea. Thanks guys. Btw when I turn the lights on the buzzing noise goes away.... ???? Every time I turn around this car has something else wrong with it -__-
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
deus-ex
Apr 13, 2015 12:29 PM
tattedlariat
Apr 12, 2015 07:55 PM
silvervtec01
Nov 4, 2001 06:56 PM
