Help Dashboard light is out!
Old Dec 23, 2010
Nice not Rice's Avatar
Nice not Rice is an unknown quantity at this point
My dashboard light is out and i cant see how fast i am going or how much fuel i have left.. if you could point me in the right direction that would be great
Old Dec 23, 2010
TRIZ's Avatar
Re: Help Dashboard light is out!
Its just one of the light bulbs that went out. Easiest way is to go to the dealership and ask for a replacement- they stock them all. It will cost you less then $10. With more information on you exact year and trim level of civic, I can give you a better idea of how much or where to order online, but still- your best bet it to go to the dealership.
BTW, welcome to the site.
http://www.hondaautomotiveparts.com/...TER+COMPONENTS
Old Dec 23, 2010
lazlong's Avatar
If only part of the cluster is dark, TRIZ is right. If it's the whole cluster, you have a bad connection or wire in the power or ground wires to the cluster. I would recommend getting a service manual, it will give you step-by-step procedures to diagnose the problrm: http://www.helminc.com/helm/homepage...051&Style=helm
Old Dec 23, 2010
CraigW's Avatar
The cluster illumination bulbs shown separate from the sockets are most likely #74 bulbs (mini wedge base) available at any auto parts store.
Old Dec 23, 2010
thanks
Old Dec 23, 2010
lazlong's Avatar
Or, if your really desperate, go to the salvage yard. They're in every Honda made in the last 20 years.
FYI: They're 1.4v bulbs.
Old Dec 23, 2010
CraigW's Avatar
I was peaved when I saw they were still using incandescent bulbs in the HVAC panel of my 2010 FA1 (neo wedge type)
They run very hot, the glass darkens over time and they are prone to failure.
Old Jun 20, 2011
teahou's Avatar
teahou is an unknown quantity at this point
I know this is an old post, but I just wanted to say that before going to all the trouble to check wires and bulbs, if all the lights are out on the dash it is more likely to be a fuse has gone bad. The fuse is under the dash on the driver side. It is a 7.5 amp fuse on the top row, 4th from the right.
Old Dec 7, 2011
marek91's Avatar
marek91 is an unknown quantity at this point
could also be the dimmer switch they tend to go or some resin
Old Apr 6, 2015
shaejb15's Avatar
shaejb15 is an unknown quantity at this point
Thanks
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
bo_red
Transmission
May 3, 2015 09:14 PM
mykel115
Dec 17, 2001 12:21 AM
