Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
D16y5 with cvt auto in 98 lx
Old Jan 31, 2015
poordude2151's Avatar
poordude2151 is an unknown quantity at this point
I'm having some wiring issues with the y5 harness plugging up to the lx dash side harness under hood. I can't plug in the cvt ecu cause off this since the lx don't have the wiring for it. Is there a jumper harness I can get to make my lx dash harness work and be able to plug up the cvt ecu without using the 1997 hx dash harness I have access too?
I have the whole hx 1997 civic.
Did the swap already just ran into this wiring issue.
Can some one point me in the right direction in using what I have without replacing harnesses or trannys. I want the cvt tranny.
Old Feb 1, 2015
Re: D16y5 with cvt auto in 98 lx
very famous in the honda swap scene.
http://www.rywire.com/rywire-harnesses-s/1817.htm
Old Feb 1, 2015
I don't see a jumper harness for the transmission ecu only the main engine ecu. This is on driver side kick panel side
Old Feb 2, 2015
call them?
they used to make custom wirings when the honda swaps were in it's infancy.
Old Feb 3, 2015
call them?
K I emailed them to see for now.
Old Feb 3, 2015
call them?
Well David at Rywire.com said to just use the y7 engine harness and buy adaptors for what's not there that I need on the y5. He said that he would make me a ecu jumper and a TCU jumper. I will need to wire up my own vtec-e since they don't make adaptors for that. I know I might have to adapt one of the transmission sensors since the y7 tranny don't have it. So I might just do this instead of use the dash harness from the HX. Just to much work.
Old Feb 4, 2015
Good luck!
Rywire knows what they are doing (unfortunately, for you), so I would follow their advice
Old Feb 6, 2015
Good luck!
I just swapped over HX main harness instead cause Rywire was going to have to make me a new harness and I was going to have to do some rewiring also and some stuff might have not worked right. The HX harness is plugging up nicely to the lx.
In the end my car will be an HX/lx hybrid and run like factory.
I ran out of money for this project and can't afford $600+ for a new harness and it maybe not work right with the CVT transmisson and vtec-e
Old Feb 6, 2015
Plus it wasn't all that bad removing the dashes from each car plus main and dash harness.
Here is my progress of my car if interested in loads of pictures.
http://www.d-series.org/forums/showcase/262465-1998-civic-lx-d16y5-cvt-auto-swap.html
mgrantaz
General
May 2, 2022 05:40 PM
solarpunk70
Apr 12, 2016 11:43 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
Bruce2
Sep 27, 2015 08:45 PM
ttamrekab
Sep 25, 2015 04:41 PM
