Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
Changed engine from vtec to non
Old Aug 14, 2010
smontgomery's Avatar
smontgomery is an unknown quantity at this point
I just put a non vtec engine in my daughters 1996 Honda EX. There is no hook up on the head for the sensor. Can the vtec system be over-ridden? Also the knock sensor was broken. The engine started right up, but after it warms up the idle varies up and down by about a 500 rpms. It also has the check engine light on. I need help please.
Old Aug 15, 2010
Re: Changed engine from vtec to non
need new ecu and wiring?
Old Aug 15, 2010
You could probably get away with the original wiring, but you'd definitely have to change the ECU. It's throwing a CEL because the VTEC ecu wants to control VTEC that's not there. I'm I'm surprised it hasn't thrown the car into limp mode (i.e. won't rev past 4000 RPM). And yes, since you have a non-VTEC engine, there's not going to be any place to put the VTEC sensor plug.
thana
Jun 15, 2020 07:05 PM
Ninetyatecivic
May 9, 2015 07:48 PM
Tybonater
Apr 24, 2015 07:03 PM
Grey
16
Jan 27, 2002 11:34 PM
Sledge
Dec 7, 2001 12:09 PM
