Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
lookin for 400whp on b16a
Old Aug 25, 2007
stand clear's Avatar
stand clear is an unknown quantity at this point
lookin to make 400whp on a b16a.made 311whp on a b16a ,but had detonation on 1 and 4 piston when i lifted the head to change lifter on valve head.
I now what to make 400whp on a b16a.My setup is stand alone computer,dis 4, 4 msd blaster coil,550cc injectors with stock fuel rail,holley 200lb/hr in tank pump, ballbearing precision turbo T3/T4 supporting 450-500 hp, aqua mist water injection sytem, usig b18c cams on a b16a head and 9 to 1 compression cp pistons, cometic 40 tou head gasket.The problem i havin is that on the detonation i noticed that all the laden ring broke on the exhaust side. is this due to post ignition on the exhaust stroke or not enough ignition.i am using 93 octane gas.With this set up, iam i capable of makin 400whp on a b16A and at what sort of boost.
Old Aug 26, 2007
ronaldo9's Avatar
Re: lookin for 400whp on b16a
You might need to upgrade your injectors. How much boost were you at to make 311whp? Alot of times detonation is caused by a lean condition. How much timing retard are you pulling? In addition what EMS are you running. Here's one of my favorite videos of a sweet turbo setup.
http://www.youtube.com/watch?v=8jNBn5UEMLc
Old Aug 26, 2007
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
I am actually in the process of building my buddies civic.......b16a2 no cams, built bottom end,JG intake manifold,walbro fuel pump, stock drag turbo kit, and 550cc injectors with fuel rail.......we made 290whp @10 psi and 330whp @ 17psi......tuned on Chrome.
We now are in the process of putting 770cc injectors in, new equal length manifold(not sure yet), new turbo turbonetics 60 trim, lsd and clutch..........
I can't wait..I'll take pictures as soon as I get my camera...
Here's a vid I out of it on streetfire....13.3 @ 10 psi against an evo (still not traction with Mickey E/Ts's) My girlfriend is annoucing the race...Here's the link
P.S. Incase your wondering that is a full ITR suspension & wheels
http://videos.streetfire.net/video/7...7b017d4a9a.htm
Old Aug 26, 2007
bullet02ex's Avatar
bullet02ex will become famous soon enoughbullet02ex will become famous soon enough
i would say you need bigger injectors to help stop the detenation.
nice 2 vids
Old Aug 26, 2007
DsevenEm2's Avatar
This is Myspace
no cams? wat does that mean.
Old Aug 26, 2007
do you think i need another fuel pump or will the in tank holeey supply the flow and pressure desired
Old Aug 26, 2007
do you think i need another fuel pump or will d holley supply the right flow and pressure
Old Aug 26, 2007
ronaldo9's Avatar
For the power you are striving for I'd just do like all the other turbo guys do and get a Walbro 255lph with a fuel pressure regulator and upgraded fuel rail and that should be sufficient for whatever power goals you desire.
Old Aug 26, 2007
ronaldo9's Avatar
Old Sep 22, 2007
7psicivic's Avatar
7psicivic is an unknown quantity at this point
deff i would look intdo the wally 255 its like 120?? i dont think that injectors are a prob just u dont have enough fuel for the injectors....
Old Sep 28, 2007
andyman97's Avatar
Turbo Guru
Who's cam trigger setup are you running? Need more details about your fuel setup. Do you even have a wideband?
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Skillzzz
Jun 26, 2015 09:46 PM
WaryDriver
May 27, 2015 05:54 AM
S2000man01
Mar 6, 2002 12:13 PM
AlexLx
Feb 26, 2002 03:44 PM
