Starting in the Civic tuning/buying! HELP!
Rep Power: 0 Starting in the Civic tuning/buying! HELP!
I'm new to all this car stuff and I really want to get into it. I would like to start out with a civic, del sol, or whatever you guys would recommend. I just want to learn about all this stuff, like B engines or whatever everyone always talks about. Can you guys explain those engines letters or whatever? I know I know nothing but you have to start somewhere right?
I really want to get into this. What year civic would you guys recommend getting? and yes I want a manual transmission.
Thanks in advance for the help!
Live for the Twisties
Rep Power: 260 Re: Starting in the Civic tuning/buying! HELP!
A B-series engine is a dual overhead cam motor that is found in Acuras and one model of Civic, a D-series motors is a single overhead cam motor and is found in Hondas like Civics, Del-Sols and CRXs.
Rep Power: 0 Re: Starting in the Civic tuning/buying! HELP!
So i'm guessing B-series would be better? If so, what are the different models of the B-series and which one is the best?
1 Post
Rep Power: 165 Re: Starting in the Civic tuning/buying! HELP!
the b series engines are on average anywhere from 130hp to 170ish hp, depending on the model check out this link for a list of the typical honda engines used for swaps http://www.jdmsource.ca/index.php?cPath=5¤cy=CAD they have hp stats with them. There are lots of choices to go with, naturally aspirated higher hp engines will run more money up front but offer reliability and less prone to damage than a turbo setup, a well done turbo setup will net more power be a little costly but you can get fanastic power out it (costly meaning you best have deep pockets). Doing the work yourself can save you loads of cash but take your time and learn it well also download the manual in my sig its a pdf manual that has a lot of good info in it.
Received 1,442 Likes
Rep Power: 338 Re: Starting in the Civic tuning/buying! HELP!
A few lines below
https://www.civicforums.com/forums/2...er-models.html
https://www.civicforums.com/forums/2...fications.html
https://www.civicforums.com/forums/2...intergras.html
Now, Mindbomber, is there a mod for this forum? these and the others need to be sticked
CarStuff
12-06-2020 12:52 PM
civic_gt
04-19-2015 08:15 AM
SSMatey
04-13-2015 06:09 PM
