Research for my 1998 honda civic ex
Hey everyone im trying to figure out if my motor can handle a small boost i dont really know much about the motor all i really know its a d series and if someone suggest a swap i heard to switch to a LS please let me know what i can do or what i cant do i already have the turbo and everything ready to go im just trying to figure out if i should buy a LS motor first
Re: Research for my 1998 honda civic ex
it will handle small amounts of boost, like 4-5 psi without building it up but thats about the limit without building the engine. There are better options out there but you can build up a d series for pretty cheap to handle larger amounts of boost. Just make sure that you are adding a fuel management system to get proper combustion of the fuel and spark timing. Running a stock setup will be guaranteed to blow it up. Check out http://www.d-series.org/forums/ for info on building it up and what works well.
ok now for other questions i want to try to put this turbo in asap
so far i have
1.1h1 Turbo vj11-8812
2.Intercooler with all piping needed
3.Getting injectors( which CC should i get? )
4.What should i do to the ECU
5. larger oil pan
and if there is alot im missing please let me know i have other things just didnt list
so far i have
5. larger oil pan
Do your homework first, there are a lot of choices for fuel management units, megasquirt, apexi fmu, safc. First decide what hp you want to get and you will have to look into building up the block for anything over very mild boost, expect no more than 175ish hp on stock internals before you run into problems. The d series blocks stock internals are not very strong. Read up on turbo builds on the link I gave you, also look into the bisimoto cams its worth the money.
Live for the Twisties
You'll also need a turbo manifold, waste gate and blow off valve. Going turbo isn't cheap and if you try to you will destory your motor, factor in at least two hours of dyno time at $150 an hour.
i have the turbo manifold, wastegate and blow off valve and i am doing my home work thats why i am asking people that know about it
i dont plan on running alot of boost right now i have some money to spend so what CC would be good for running stock right now? someone told me 450cc would be alright for now.
also for my FMU what Raito do i get or start out yet how would i do the math to know please if you could explain that would be great
450cc should be ok to start out with at lower boost, the stock fuel pump should be able to keep up to that, the air/fuel ratio will be adjuted with the tune, a fuel management unit or (fmu) can be tuned that is what the dyno is for, they can adjust it for best performance. Just make sure they do not tune to to aggresively as it will blow the motor up, let them know that you are still wanting decent reliability on the motor.
450CC injectors would work well and you can save money on buying after-market injectors by buying the OEM RDX injectors as they are 450CC.
i am sorry this is going to sound stupid how do you tune a car do i use my computer with some type of program please explain i am so lost or is tuning just buying parts and puting them in
research first, check list of what you want, what you need, then start getting parts...
why you so in a hurry? that could get very expensive the way you doing...
start here... a few lines below your own thread. Engine is not yours, but same theory applies...
https://www.civicforums.com/forums/2...ies-motor.html
im trying to get alot done fast before summer i have the money so i will be buying all parts fast this is why im looking for information now
i have the following already
Turbo Charging 1998 honda civic
Check list
1.Turbo
2.Turbo Manifold
3.Blow off vavle
4.Fuel regilator
5.intercooler (w/ all piping needed)
6.Larger Oil pan
7.WasteGate
8.boost controler
Getting
1.450cc Fuel injectors
2. Fuel managment system
3. ECU( i was thinking hondata but whats the best let me know your thoughts
Check list
1.Turbo
2.Turbo Manifold
3.Blow off vavle
4.Fuel regilator
6.Larger Oil pan
7.WasteGate
8.boost controler
Getting
if i wanted to do an engine swap for my car which is a good motor to get the motor i have no is d16y7 and yes i plan on boosting either this one or the swap motor
for mild boost the d16y8 would not really need any buildup but the d16y7 would if you are planning over 4-5 psi, but on the bright side a built up d16y7 can be less costly and prone to damage as there are less things to worry about like a vtec solenoid. The b series engines tend to handle boost well so its entirely your call. A mildly boosted d16y7 would probably get you around 150ish hp without port n polishing or cam, and a d16y8 would probably be closer to 170ish hp. Those are hp numbers at the crank not a the wheels. There are lots of turbo build ups done for the D series engines though some in excess of 400 hp so its not without its merits butthe 96-00 SI (US Model or SiR canada model) b series can get you those numbers without a turbo setup.
well i just got the piping needed to setup the intercooler and turbo i was wondering can i put the turbo in with everything stock and run low boost for now will stock fuel injectors work for now with out a tune i just want to throw it in for now then i will start to upgrade more i have a d16y7 motor
you would need to look at a high flow fuel pump more than a high pressure one as the fuel pressure regulator is what takes care of that, a fuel ratio if 10:1 is usually what you look for but those who do tuning would be better to ask about that as I do not do a lot of tuning.
jessicakaybby
Apr 20, 2015 12:11 PM
