are springs and struts the same
Old Jan 10, 2012
lamar's Avatar
lamar is an unknown quantity at this point
are the springs and struts the same on a 96 civic hatchback as a 96 civic sedan? i put the sedan on my hatch and seams to sit up higher. thanks Lamar
Old Jan 10, 2012
Re: are springs and struts the same
no, springs are springs, struts are struts :P
Old Jan 10, 2012
Look up each car in a parts catalog, see if the part numbers for the springs are the same between the 2 cars.
http://www.hondaautomotiveparts.com/
I'd guess they are different due to the weight differences between the two cars. Hatch should be lighter.
Put the hatch units under the sedan, instant lowering kit!
Old Jan 11, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
I would have to check the spring rates to see but i would imagine the sedan has a higher spring rate(stiffer springs) due to how much more it weighs..so if you put the sedan ones on your little car they don't compress the springs as much...
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
