sway and strut bars
Old Jun 13, 2011
nicole's Avatar
nicole is just really nicenicole is just really nicenicole is just really nicenicole is just really nice
sway and strut bars
I have a 99 ex and I thought about putting sway bars along with strut bars on her but do i need them?
Old Jun 13, 2011
civic0427's Avatar
civic0427 is an unknown quantity at this point
Re: sway and strut bars
It will stiffen your car up some. It wont hurt it but from my experience you wont notice it that much. I had a 96 and didn't notice a huge difference but go for its. Inexpensive upgrade!
Old Jun 13, 2011
Good bang for your buck upgrade. A solid construction strut bar will make your steering more responsive and sway bars will decrease your body roll.
At first, when I installed my strut bar, I didn't feel much of a difference, but once I took it off, the difference was like night and day. Definitely one of those "you don't know what you got til it's gone" kinda things.
Old Jun 13, 2011
nicole's Avatar
Are there better brands or are they all basically the same?
Old Jun 13, 2011
MindBomber's Avatar
Live for the Twisties
If you do a site search you'll find a lot of information on strut bars; it's not necessarily all dedicated to 6G, but 7G and earlier suspension geometry is similar so the concepts transfer right over. Here's a quick explination though..
Strut bars are a passive suspension upgrade, they lock the
the strut towers together and prevent the chassis from flexing outside the ideal suspension geometry. A good way to demostrate the purpose a strut bar serves is to drive one wheel up on a curb, feel the car flexing, that's what a strut bar reduces. In terms of overall performance they make a difference of thousands of seconds on a track car, so don't expect a huge performance boost, but your steering will definitely feel tighter. Neuspeed, spoon, cusco, dc sports, mugen and etcera all make great strut bars, but as long as the one you buy looks solidly built it'll do it's job.
Sway bars are an active suspension upgrade, they make a huge difference in handling by reducing body roll and oversteer. If your serious about suspension upgrades this should definitely be one of your first purchases. You can put on a GSR sway for a relatively low cost with a few oem parts, it's 14mm in diameter and will make a small handling improvement. You can step up to a 22mm ITR or aftermarket sway bar as well, they will make a bigger difference in handling improvement but you also need a subframe brace for anything over 19mm.
Old Jun 13, 2011
nicole's Avatar
Thank you
Old Jun 13, 2011
not really sure about strut tower in 6G, but since the anchor is high up on the fenders, maybe it could improve.
Sways - only the rear, no need to upgrade front, it will rather make handling worse changing the fronts.
Old Jun 13, 2011
nicole's Avatar
i would have to upgrade my shocks and everything as well right?
Old Jun 13, 2011
MindBomber's Avatar
You don't need to, but they're an integral part of your suspension so they would be my first purchase.
Old Jun 14, 2011
they are actually required when you upgrade springs, so if they are still working with the stock springs, should be fine unless car starts to be bouncy or too harsh in bumps, or leaks, etc, etc
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
