Help Help Help...
Old May 14, 2009
southaflow's Avatar
southaflow is an unknown quantity at this point
Help Help Help...
Hi, i have a 2000 SI, the car was lowered already when i bought it, which was 2 years ago, right now everytime i drive my car and i hit any bumps my car just bounces too much, more than i remember when i bought it, like way more... what could the problem be??..
Old May 14, 2009
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Re: Help Help Help...
Strut/shocks may have went out and may need to be replaced. If they didnt replace the OEM ones and just lowered it, this would make sense. Just an idea. Others will be able to add more.
Do you know if they are the OEM strut/shocks? Because the OEM cant handle a very big drop.
Old May 15, 2009
d350l4710n's Avatar
d350l4710n is an unknown quantity at this point
Yep ... sounds like they only replaced the springs with lowering springs which would cause that awful bounce when you go over bumps. My buddy has a 95 integra that he only replaced the springs on and he has the same problem as you. Sounds like your shocks have gotten worn down to the point of not working in the 2 years since it was lowered. You will need to replace the shocks with something more reliable. I advice spending the extra money for some good full coilover dampers that has ride height adjustment so you won't have that bounce when going over bumps.
I saw a full set of skunk 2 full coilovers on ebay for $700 or so ... you can find some no name brands for cheaper too, but research the manufacturer before you buy them (google).
Old May 18, 2009
southaflow's Avatar
Thanks Guys..
Old May 18, 2009
Zzyzx's Avatar
Autocross Junky
100% dampers. pick up some Koni, Bilstien, Tokico or what ever brand you like and call it a day.
mrohitredd
Apr 15, 2015 08:13 PM
FlippedOut
Feb 11, 2003 06:27 PM
Jotosuds
Detailing
Nov 2, 2002 06:31 PM
