Don't want to lower
Old Oct 29, 2007
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
Don't want to lower
I am looking to replace factory struts on a 98 ex and believe it or not, I read the articles on here about coilovers, struts, and shocks. What I need help with is I don't want to lower the car. I want the handling of a lowered car but without having to buy adjustable coilovers. I could always just buy them, but I want to know if there is a cheaper alternative.
Old Oct 29, 2007
AmbulanceMonkee's Avatar
Re: Don't want to lower
why don't you want it lower?? i'm not advocatiing slamming it, so the wheels tuck, but everything looks better with a subtle drop. if you really want to keep it stock height, you get some tokico hp dampers, and run stock springs. alternately, tein h tech springs are about a 1" drop all around, which is minimal, and the s techs are about 1.5". there's really no reason to buy coilovers if you don't want to lower it, stick with shocks/springs, it'll be cheaper that way, and accomplish the same thing.
Old Oct 29, 2007
robbclark1's Avatar
Retired suspension supermod.
If you are going to upgrade the shocks, then you might as well lower 1".
Koni shocks, eibach pro kit, F/R camber kit, rear sway bar.
Old Oct 29, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
You wont get it. Lowering the car lowers the center of gravity, which in turn makes the car more stable, additionally, lowering springs are firmer to cope with the reduced travel, which makes the car less prone to body roll.
Old Oct 29, 2007
The reason I didn't want to lower the car was because of 17 inch rims and having to deal with negative camber. If I only drop it an inch, I wouldn't think so, but would negative camber be an issue? And will I still have room to use my 17s still?
Old Oct 29, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
you will be able to drop it probably 2 inches. either way u will have camber that isnt stock specs so just get a camber kit
Old Oct 29, 2007
robbclark1's Avatar
Dude, there have been people who fit 17's under a 2". 1" drop will make camber negative. To fix this, you get a camber kit. Besides offering you the ability to put the wheels back to spec, you also have the opportunity to adjust camber settings. Most people think that just lowering the car improves handling, but alignment settings are extremely important.
Old Oct 29, 2007
Yeah I knew that when you lowered a car that you typically had a neg camber but from what I understood from some people was that a short drop wouldn't result in neg camber. Does it depend on the application or is this just not true? And anyone that sells coilovers typically sells camber kits too right?
Old Nov 12, 2007
dirty honda's Avatar
dirty honda is an unknown quantity at this point
I have always been interested in this to because i live in MN and driveing on dirt is a favorite passtime of mine i would rather not have a real low car but a bit more stiffness would be great
Old Nov 12, 2007
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
tokico hp (almost the same cost as stock but better in all ways, smoother ride, better handling)
tein s-techs (~1 inch drop, retain the smooth ride you know and love, reap the benefits of lowered center of gravity and better rates and response)
camber kit (save the tires)
DO WORK!
btw coilovers are corny...good for getting on the ground, good for nothing else.well the expensive ones are, but i dont think you are in that position
Old Nov 19, 2007
HyeHonda05's Avatar
Official Wish He Knew It All
DO WORK!
S-Techs are more than a 1'' drop......I have them...they are are about 1.5'' closer to 1.7''.....if he wants a 1'' drop...get the eibach pro kit or the tein h techs....but S-Techs might be more than what he is looking for.....
Old Nov 19, 2007
Technical Assistant
i confused the h with the s
Old Nov 19, 2007
HonCiv02's Avatar
HonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond repute
with a short drop, there is a chance that your camber will be within spec, but having a camber kit gives you the adjustability to put it where you want. you will also be able to buy everything from the same place. i think a 1-1.5" is perfect for our cars. i live around some really crummy roads with a 1.5" drop and it isn't bad at all; you will really notice a difference too.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
EvilTwin
Nov 8, 2001 12:17 PM
