Rear Sway Bars
Old Jan 10, 2007
  #31
Zzyzx's Avatar
Autocross Junky
Depends... have you optimized your alignment and how is the car handling now?
Old Jan 15, 2007
  #32
dk1021's Avatar
dk1021 is an unknown quantity at this point
I have a 22mm DC2R sway bar on mines with a megan tie bar ... I had the tie bar on before the sway bar, so dont know how it feels without the tie bar lol ...
Old Jan 16, 2007
  #33
Zzyzx's Avatar
Autocross Junky
Originally Posted by business
I understand what a sway bar is but exactly how does it push all of your suspension down at the same time?
It doesn't. An anti-roll bar basically transfers some of the inside wheels sping rate to the outside wheel... increasing the rate of the spring trying to be compressed (so it compresses less, and you have less chassis roll)... the down side of them is that in doing their job, they also increase the amount of lateral load transfered in that turn, which reduces the amount of traction that end of the car can generate.
Old Jan 16, 2007
  #34
HondaLuver's Avatar
Its a celebration bitches!
i like having a controled slide around turns sometimes.. its fun
Old Jan 20, 2007
  #35
burke420's Avatar
The World Is Yours!
Progress Rear Sway 20mm
Old Jan 21, 2007
  #36
robbclark1's Avatar
Retired suspension supermod.
It's 22mm for the nonadjustable and 24mm for the adjustable.
Old Jan 29, 2007
  #37
knight_321's Avatar
knight_321 has a spectacular aura aboutknight_321 has a spectacular aura about
wat year is the RSX with the 19mm rear sway, i want to get it from a dealer but i not sure which year it is,
also does the 2002 front sway just bolt on directly to the 05 civic
Old Jan 30, 2007
  #38
LT2004ever's Avatar
I wil fix vBPlaza today
Honda Sway Bar Specs
the 19mm is the base RSX of 04, 05, 06
And they just bolt directly on to a ... well do u have a lx? ex? cause the ex has a rear sway bar thats like 16mm i think. well my 01ex has a 16mm one, and yea it goes right on your stock endlinks and u just use the bushings that came with it and you will be good. Theres alot more involved if u dont have a swaybar already stock.
Old Jan 30, 2007
  #39
electric130's Avatar
Originally Posted by slowwhitecivic
you guys know where i can purchase a cheap rsx rear sway bar..
https://www.civicforums.com/forums/1...-sway-bar.html it's a 19mm which is the base. the type-s has a 21mm.
Old Feb 6, 2007
  #40
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
What kind of work would I be looking at...i want to go with the RSX rear for my 01 LX sedan...i think the front will do just fine stock.
Old Feb 6, 2007
  #41
LT2004ever's Avatar
if you are going to do that u need the RSX Bushings, Brackets, and the endlinks. then of course u r gonna have to drill into your baby to mount those brackets. so just follow the DIY in the 7thgen section
There ya go, you should be all set now, if u are gonna go the RSX way...
Old Feb 6, 2007
  #42
Zzyzx's Avatar
Autocross Junky
The alternative would be to buy the progressive made mounting kit.
Old Feb 6, 2007
  #43
Technical Assistant
I may considering going with the Progress rear bar and kit...whats this story I hear with the breaking endlinks?
Old Feb 6, 2007
  #44
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
The Progress bar has a different design than OEM. It puts the endlinks at a different angle than stock which has caused some people to break endlinks. I will say not everyone that has the Progress bar has broken them so there's a chance that you may not have any problems.
Old Feb 7, 2007
  #45
EXsmellsbetter's Avatar
Mr. Treehorn treats objects like women, man!
EXsmellsbetter has a spectacular aura aboutEXsmellsbetter has a spectacular aura aboutEXsmellsbetter has a spectacular aura about
The car handles awesome for an economy car, lol. I have really decent tires too, so that's good. I always want to be able to turn harder, though (to show everyone that driving isn't about a straight line, ya know?). My alignment is alright, the local tire shop adjusted the camber as much as they could and the tires are wearing really good, so no camber kit yet.
Old Feb 7, 2007
  #46
Zzyzx's Avatar
Autocross Junky
Awsome wasnt really the description I was looking for....
By "how is it handling now" I ment, Does the car tend to understeer, Oversteer ect... when/where does it do either ect ect ect..
Old Feb 12, 2007
  #47
Haha, I hear ya. I think when I'm turning corners at super high speeds, there feels like there is some oversteer going on, but other than that it feels pretty neutral.
Old Feb 15, 2007
  #48
civic05acer's Avatar
civic05acer has a spectacular aura aboutcivic05acer has a spectacular aura aboutcivic05acer has a spectacular aura about
just wonderinf if a 27mm progress front sway is too big. i want something that can minimize my sway. im just thinking ir might me too big for my 05 lx. or should i go with a rsx 19mm.
Old Feb 15, 2007
  #49
phantomninja's Avatar
phantomninja has a little shameless behaviour in the past
Instead of spending alot of money on a aftermarket company, just get the stock 01 civic lx front sway bar, i think it's like 25.4mm or something like that not 100% though, and i guess it depends on what you want to use the car for too, i track my car and i have the stock 01 lx front sway with the 06 rsx type s rear 21mm sway and it's freakin perfect for my driving, no understeer at all just a tad bit oversteer
Old Feb 15, 2007
  #50
this is a daily driver. but everyday i have to go on a roundabout and my car sways to the right alot. i know someone selling a 27mm for 50 and i can pick up brackets for 20 and ill find endlinks some where.
Old Feb 15, 2007
  #51
haha alright, looks like you have your mind set up so go out and do it actually if you want to take that round about faaaast just get stickier tires haha
Old Feb 15, 2007
  #52
LT2004ever's Avatar
get some of greys endlinks... i heard they are nice
Old Feb 15, 2007
  #53
what year and model car you have?
Old Mar 15, 2007
  #54
LT2004ever's Avatar
Originally Posted by CivicDuty
Don't forget to buy the mounting bushings and make sure you use a bunch of penetrating oil on the end links. You need to use an allen key in the end of the bolt to hold it while turning the nut. The allen portion usually fills up with rust and strips easily so be careful.
If you try to hold the bolt with vise grips you'll bugger the threads. Either way, don't be suprised if you need new end links before you're done. I did mine early in the car's life and managed to escape unscathed. If you live in a warmer climate (unlike me) you may not have a rust issue, but, still be careful.
crap.... i wish i woulda payed more attention... DANG!
https://www.civicforums.com/forums/7...o-problem.html
Old Mar 15, 2007
  #55
Zzyzx's Avatar
Autocross Junky
Learn to ignor it, and look at how the car is actually handling.... rather then what it may look like when turning.
so, check tire wear. As in, are you cornering on the tires side walls when you do that corner? and how much static negitive camber are you running? And During this turn, how is the car handling? Is it understeering? Oversteering? and what are you as a driver doing when either if these happen?
Old Mar 24, 2007
  #56
Stykman's Avatar
Stykman is an unknown quantity at this point
Re: Rear Sway Bars
I recently got a 2007 EX sedan. Has anyone swapped the SI sway bars into one of these? I'm mostly thinking the rear needs to be heavier to reduce body lean and understeer.
BTW, this page might be of interest for diagnosing handling:
http://www.rogerkrausracing.com/Tech...verunder.shtml
Old Mar 24, 2007
  #57
LT2004ever's Avatar
Re: Rear Sway Bars
nice find but yea i posted something similar to that some time ago hehe
https://www.civicforums.com/forums/4...in-around.html
has a little more info than when i posted
Old Mar 27, 2007
  #58
Stykman's Avatar
Re: Rear Sway Bars
When I was autocrossing I found tire pressure made a significant difference, and did so when I applied that on the street as well. What I basically did was figure out the relative balance of the car (front/rear) and then adjusted the air pressure about half as much. In other words, if a FWD car is 60/40, I ran 36 lbs in the front and about 30 in the rear. That worked well for me.
Still wondering how the the Si sway bars would work on the EX. The rear alone would probably do what I want, but the Si has that point-and-shoot handling ....
Old Mar 29, 2007
  #59
LT2004ever's Avatar
Re: Rear Sway Bars
Like the Si rear is only 17mm, as compared to a 12 or 13mm on the civics, it would be pretty nice, but y not do for a 21mm or a 19mm one from the RSX's. But yeah it "a thicker rear sway bar will make the car more prone to oversteering but since the rear is not that much bigger than the front on my setup it makes the car a bit more neutral rather than understeering with the factory rear sway. I didn't want to go 19mm bc I thought that would be too big but alot of ppl love it. The 19mm seems to suit those with 2001-2002 civics with the bigger front sway bar." -ronaldo9-
hope all this helps u out
Old Mar 30, 2007
  #60
Re: Rear Sway Bars
i'm about to get a 19mm rear RSX-S sway bar to put on my 02 ES1. got some grays for it too.
