Oil pressure light
Re: Oil pressure light
Did it work before?
Is the bulb good?
Pressure switch should ground the wire to turn on the warning light. Does it?
Is the bulb good?
Might want to follow the circuit traces on the cluster board and make sure the one for the light actually meets at the location where you moved the wire
Volt-ohm testing at the light bulb socket on the board with everything hooked up, is bulb missing the power side or the ground side? Figure that out then you can track whichever side is missing instead of guessing
JAyer1654
Jul 15, 2018 10:02 PM
