2000 Honda Civic EX Cassette Player has no power
Old Jan 23, 2014
HondaDRVRFCC's Avatar
HondaDRVRFCC is an unknown quantity at this point
Question 2000 Honda Civic EX Cassette Player has no power
My 2000 Honda CIVIC EX came with a CD player. Several years back I added a Cassette Player from Honda and it was installed by the dealer. Now though we are not using it for cassettes my daughter wants to play her iPod via the cassette player. When she complained she is unable to use it I checked and found there is no power. Normally when you switch on the headlights the controls get illuminated. I don't see that happening. So I am assuming there is no power. When I insert a cassette, it does not get loaded and it is pushed out. The CD player which is integrated with the cassette player has the power.
Some suggestions were to check the fuse. I don't know which one to check. I read it is the same fuse that is connected to the cigarette lighter. However the cigarette lighter has power.
Any suggestions would be appreciated.
Thanks
Old Jan 23, 2014
Re: 2000 Honda Civic EX Cassette Player has no power
The add-on player is connected directly to the stock radio. No other wiring. \
If the stock radio works properly, the add-on unit should also work properly.
Pull the radio out and make sure your player is still plugged in.
See if there might be an external fuse in the back of the unit to check.
There may be an internal fuse too. Remove lids and dig into the electronics?
Old Jan 24, 2014
Thanks for the reply. I will check that over this weekend and update.
Old Jan 25, 2014
Fixed.
I opened the fuse box under the hood and removed the fuse #47 (Backup Radio) and cleaned the edges and put it back. Radio got reset and asked for the code. Fortunately I had the code and now both CD player and cassette payers are working.
See the chart for reference. http://troubleshootmyvehicle.com/hon...fuse-relay-box
Old Feb 3, 2021
Lucila Pacheco's Avatar
Lucila Pacheco is an unknown quantity at this point
Thanks
i just got my honda and thats whats wrong with my car. The headlight, cigarette lighter, and that cassette doesnt have power. What should i do??
Old Feb 3, 2021
FRSam's Avatar
Click Here
Check fuses. If not, it’s probably a wiring issue.
cl6120
Feb 23, 2013 02:07 PM
CivicStan
May 22, 2011 01:12 PM
hypno
Oct 20, 2008 07:10 AM
Lesclaypool
Jun 18, 2007 01:18 AM
DistinctiveBP
Mar 28, 2004 04:03 PM
