Need help bad!!
Old Apr 24, 2013
Sabuno's Avatar
Sabuno is an unknown quantity at this point
Need help bad!!
I need to know what harness plugs into the door harness so my power windows and locks will work if anyone has any info please help me
Old Apr 24, 2013
Re: Need help bad!!
Could you make the post just a little more vague please?
I almost had some idea of what you were trying to ask.
Remove a few more clues so there are none and we'll be all set.
Go to this site, or one of the many Honda parts catalog sites out there.
http://www.hondaautomotiveparts.com/
If you are in Canada, you need a Canadian dealers site.
Go through all the steps to pick out your car.
(Even better would be to simply enter your VIN into the catalog so it eliminates most of the wrong choices for you.)
Then find the list of "System\Component" choices for areas of the car. Scroll to the bottom of the list, pick "WIRE HARNESS"
You should see a picture box like this one:
Look in the parts list for the one labeled "WIRE HARNESS, FLOOR".
In this example it is item #2.
I'm pretty sure this is the harness that reaches each door and has all the broken wires that I figured you had from the last thread you made about this problem.
Call the parts seller and speak to a human, make sure of what you are going to order first.
HTH
Old Apr 24, 2013
Sabuno's Avatar
Re: Need help bad!!
Thank you I appreciate this ill check it out
SimpleUser
Apr 24, 2021 02:54 AM
Green02civic
Jul 27, 2015 10:48 PM
cukaracha
30
Jul 26, 2015 12:01 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Bounddyy
Jul 8, 2015 11:22 AM
