1998 Civic LX randomly dying (ignition problem?)
Old Sep 11, 2012
literallarry's Avatar
literallarry is an unknown quantity at this point
1998 Civic LX- the engine has been randomly dying while driving for some time now. It happens at all speeds and is very unpredictable. When it does die, it is only the engine. All the power remains on and check engine light comes on. It usually takes about 10 minutes of trying to restart and the engine will fire back up. The engine will only fire back up once the check engine light goes off, again which takes about 10 minutes to happen.
However recently I tried jiggling the key when it died. The check engine light went off immediately and I was able to immediately restart the car. I assume it could be an ignition problem but I don’t know what jigging a key equates to. Anyone know??
P.S alternator and battery were tested and proven to be good.
Thanks
Old Dec 25, 2012
rr081709's Avatar
Kevin
rr081709 is an unknown quantity at this point
Re: 1998 Civic LX randomly dying (ignition problem?)
There is a post in another section of this site where someone has claimed to have had a problem with an ignition switch... There may have possibly been a recall on the device and it was replaced for free. I believe they had the same model car as yours, but i could be wrong. you can check at this site: http://www.ahm-ownerlink.com/prod_home.asp
If nothing else at least this could be a direction to look in... hope it helps!
rcolosi
Apr 29, 2015 07:48 PM
twtron
Apr 17, 2015 12:09 AM
McD
Apr 16, 2015 10:46 AM
Hrddrvs
Apr 11, 2015 11:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
