Pioneer Head Unit Install help
Old Sep 6, 2012
JDM for Lyfe's Avatar
JDM for Lyfe is an unknown quantity at this point
i bought a pioneer deh 2400ub deck and bought a harness adapter. there are two wires on the factory adapter that dont have wires on the deck wiring (orange illumination dash lights & blue power antenna) and a blue and white wire on the deck (system remote control). Im knew to this and it is my first install. Just wondering where I would hook these up? Thanks
Old Sep 6, 2012
Re: Pioneer Head Unit Install help
ok i found out to cap off the orange wire. and the blue and white is for an amp. but where do i put the blue wire and also there are 2 black ground wires and one is larger than the other. do i hook them together or do i hook them to separate grounds? i dont think they are llong enough to even hook to a ground
Old Sep 6, 2012
GolNat's Avatar
Prelude Owner
You can hook the 2 grounds together. Power att can go to ignition if there is no wire on the hu. That way it's hot when you turn your key on.
Old Sep 6, 2012
is the power antenna neccesary? can i just cap it off?
Old Sep 6, 2012
GolNat's Avatar
Prelude Owner
I thinks it's only if you have a power attn that pops out when the radio is turned on. Is it a factory wire? What year civic is it?
Old Sep 7, 2012
yeah your right, everything works fine. thanks!
4 banger
Jun 5, 2015 01:44 AM
HondaHomer
May 14, 2015 12:24 PM
mugenca
Apr 16, 2015 12:15 AM
mwwhonda
Dec 5, 2001 10:52 AM
PimpBot5000
Nov 26, 2001 07:15 PM
