scattered info (want to replace speedo bulbs)
Old May 25, 2012
concepttheman's Avatar
concepttheman is an unknown quantity at this point
I simply want to replace the screw in bulbs for my honda civic lx 4 dr auto.
Too much scattered info on it.
I don't want to do any wiring or soldering.
Does anyone know about getting the right number.
Im confused. From what i know is u have to have maybe 9-14.8 volt bulbs (leds)
I called the company and they said they dont get hot.
Is this link a good one?
http://www.superbrightleds.com/cgi-b....html%23ipanel
Please reply....+1 waiting
Thanks
Old Oct 16, 2013
licona4044's Avatar
licona4044 is an unknown quantity at this point
Re: scattered info (want to replace speedo bulbs)
its really easy to doit on that dash i just took mine apart last night has total of 7 bulbs that light up the gauges but nothing serious just screw off pull the small bulb out put the new one then screw it back on and done and i actually ordered my light bulbs from the same web site but before you order anything make sure the led bulb fits cause if its too big it wont fit i know the ones i bought fit for sure this is the second time doing this would u like me to send you the links? and also theres 2 bulbs on top you will see them when u take it apart if you compare them to all thenother ones you take off they are the only 2 that dont have like a blue cover they are clear but the reason why cause where those 2 specific ones light up theres like a blue film tint you have to take that off in order to get the actual white LED if not its gonna look blue.
Old Nov 3, 2013
azkicker0027's Avatar
azkicker0027 is an unknown quantity at this point
The ones on top actually give the lighting for the cluster. The needles and numbers reflect off the light from top. I changed those to amber and kept the backlighting for the numbers stock color.
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
SWEETRIDE
Nov 27, 2001 05:52 PM
aZnVoYCe
Nov 15, 2001 04:48 PM
wawacito
Nov 5, 2001 03:32 PM
