ek power window problem....HELP!!!!!!!!
Old Nov 14, 2011
rodgerrogelio's Avatar
rodgerrogelio is an unknown quantity at this point
i have a 96 civic lx and i have a problem with the power window. the driver one works when it wants to and when it doesnt you open and close the door a couple of time and it starts to work agian. wierd. and none of my other windows work and i know its not the motor cuz i put new ones thinking it was that. and i had the main driver switch replaced also but still nuthing. does any body know what it can be. i going crazy with the windows. thank you
Old Nov 15, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Re: ek power window problem....HELP!!!!!!!!
did you try lubricating the tracks at all? did you test to see if any current is flowing to the switch? could be a wiring issue in the door, where the black rubber sock is.
Old Dec 16, 2011
OrlandoCivic's Avatar
OrlandoCivic is an unknown quantity at this point
DIY power window repair people. Call Power Window Repair in Orlando 407-415-5401.
They are a mobile power window repair company that services Orlando. But, they also have a website where you can buy DIY window motors, regulators, and switches for Honda and all makes AT THE PRICES INSTALLERS & SHOPS PAY..
They give advice and tips for free.. www.powerwindowrepairservices.com
Old Aug 17, 2012
keyboardduder's Avatar
keyboardduder is an unknown quantity at this point
I'm having a similar problem.
In terms of lubrication, what would be your best recommendation so it stays potent in the rubber window track?
Old Aug 17, 2012
GolNat's Avatar
Prelude Owner
White lithium grease would wor good.
Old Aug 17, 2012
i would not recommend white lithium grease, it will stain all over the place and get on the window. it is supposed to be used on metal, not rubber. use clear silicone spray lube. it only lasts a couple months, but easy to spray when you need to by rolling the windows down.
Old Aug 17, 2012
CraigW's Avatar
The rubber tracks are pretty slick on their own & are made to work as is... just keep them clean.
Any lubricant you apply will attract dirt.
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
1khilari
Jul 9, 2015 08:12 PM
ballmich
Jul 9, 2015 11:59 AM
hayden55
Jul 8, 2015 11:38 PM
cgavin1
Jul 7, 2015 07:10 AM
