Mouting Cooling Fans
Old May 31, 2011
nickrolando's Avatar
nickrolando is an unknown quantity at this point
Okay so this is a follow up thread to my original thread about the dual amplifier install. Here is the picture of how my amps must be mounted because they both cant be mounted flat because of the amount of room on rear of back seats: (Both amps when doing the fan installation will have carpeted wooden boards behind them.)
Better picture of 4 channel:
Here is a picture of the two fans I just got today in the mail:
I want to mount these to look as neat/clean as possible. I'm going to put a fan on each amp. Where should they be mounted considering the way the amplifiers are mounted? Also considering can't use screws to keep them down what should I use to keep them secure?
Detailed help is most APPRECIATED!
Thanks in advance all. Hopefully after this job i can finally not have an overheating issue once and for all.
Old Jun 8, 2011
Re: Mouting Cooling Fans
bump. i used industrial strength velcro to secure the four channel one but when it gets really hot. it falls. any ideas?
Old Jun 11, 2011
JackedByJack's Avatar
JackedByJack is an unknown quantity at this point
the heat is causing the sticky side to become less adhesive, best bet is to find screws or clamps that require screws
Old Jun 12, 2011
Luckily, in the spot I mounted the fan, I was able to find one spot where I could get a screw into metal and believe it or not, the one screw seems to be holding it there really well. thanks for the help to all!
Old Jun 12, 2011
no problem it should hold really well even with one, two would be the best but dont push it
alinaray
18
Aug 24, 2015 01:04 PM
MrOldskool
Aug 18, 2015 09:58 AM
FutureCivicOwnr
Aug 11, 2015 10:59 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
