Dual Amp System Install
Old May 27, 2011
  #31
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: Dual Amp System Install
I think you have bigger problems than cooling. Your PM replied to.
Old May 28, 2011
  #32
nickrolando's Avatar
nickrolando is an unknown quantity at this point
Replied to yours. please get back to me asap. i really appreciate all your help
Just wanted to let others know as well
Last night, I delivered food for 4 hours straight, after 45 minutes amp was very hot but put both rear seats down and with the breeze the 4 channel amp barely even got warm?
Any ideas from that?
Old Jun 5, 2011
  #33
ckeboss's Avatar
ckeboss is an unknown quantity at this point
If you have changed nothing else, it's heat/orientation that is your issue. Why not just mount the amps on the floor of the trunk with fans?
Old Jun 8, 2011
  #34
They are mounted same way but now have fans on them. Now im having a problem with fans staying up when it gets over 80 degrees outside. Please see my other thread on fan mounting. thank you!
Old Jun 8, 2011
  #35
Kennykid2002's Avatar
Kenny the Ricer
You have ventilation issues
You might have fans now, but those fans are blowing the same hot air around in your trunk
What I did to cure my ventilation issue was to remove the rear 6x9's to provide airflow into the trunk
But I doubt you're wanting to remove your aftermarket 6x9's after paying for them.
Another option I was thinking of...
Theres an air vent on the drivers side of the trunk, if you pull back the lining
Maybe if you removed it, cut a hole in the lining, and fashioned some kind of air duct with a filter on it, you could bring fresh air in (Kind of like a cold air intake for your trunk)
The only problem with that is...if it's raining, then water will get into it, as it is directly behind your rear wheel well
Old Jun 8, 2011
  #36
The fans seem to be working now though. Please see my other thread on fan mounting kenny, I'd really appreciate it. Velcro doesnt seems to be holding it enough. Fell twice already when its super hot outside.
Old Jun 8, 2011
  #37
electric130's Avatar
buy some metal angle brackets from lowes in the lumber section. you can screw the fan to it, and then mount them to the vehicle (obiously don't screw into the amps) with them blowing on the amps.
Old Jun 8, 2011
  #38
Kenny the Ricer
Either way you mount the fan, on a 90+ day, it'll do you no good if all you're blowing is hot air around
Old Jun 9, 2011
  #39
I know not to screw them into the amps. I'll take a picture and show you how its mounted as of now. Once you see the picture you'll understand why its hard for me to use the metal angle brackets.
Does the sticky side of 3m Dual Lock stick better then industrial strength velcro?
Old Jun 9, 2011
  #40
anything gets hot enough, and no glue will stick
jtdunn4life
Oct 27, 2015 03:33 AM
MamaBear2015
Jun 11, 2015 07:33 PM
