Chassis door wiring bad
Old Apr 18, 2011
kee68's Avatar
kee68 is an unknown quantity at this point
can someone explain how to repair wiring in rubber conduit going to left door on a 1996 civic ex? Is that a plug that is green under the boot cover? How do you get it apart as my windows and locks quit working and there are bare wires showing.
Old Dec 11, 2011
96civ's Avatar
96civ is an unknown quantity at this point
Re: Chassis door wiring bad
yes I need a diagram as well. Windows stopped working and can only get power locks to work now when door is all the way open. When I removed the boot 3 or 4 wires came out of the part and 1 wire that I assume is a ground since it is black is totally apart. Can someone tell me where to find a diagram and tips on how to secure the wires back into the part where they just fell out?
Old Dec 11, 2011
CraigW's Avatar
A scanned version of the 96-00 factory manual is free on the web...you just have to search it out.
Every answer would be in there.
Old Jun 17, 2012
stfoxx's Avatar
stfoxx is an unknown quantity at this point
I had to remove the front fender go get more room to work on the plug. I found how to remove the fender on you tube.
dinsum
May 28, 2015 09:30 PM
MamaBear2015
May 18, 2015 07:37 PM
werdnahall
May 17, 2015 11:37 AM
MamaBear2015
May 3, 2015 02:17 PM
supercivic01
South
Nov 30, 2001 11:27 AM
