Rear Defroster Not Working
Old Oct 20, 2010
WI-JBIRD's Avatar
WI-JBIRD is an unknown quantity at this point
1999 Civic EX Sedan
No rear defroster when the control button is pushed. Button lights up and I can hear what sounds to be the relay kick in. I've tested the grid for continuity with a multimeter and the grid is fine. However, there's no power coming back to the post on the sides of the grid. What am I missing?
Thanks,
Jay
P.S. It's starting to get cold here in WI and I will need the rear defroster soon.
Old Oct 20, 2010
lazlong's Avatar
Re: Rear Defroster Not Working
To be clear- the grid is fine but, your not getting power to it?
I had this happen and just ended up running a new wire from the switch in the dash to the post on the window as I didn't want to find the short.
Old Oct 20, 2010
02civicsi02's Avatar
Low and slow!
Check fuses or the connection on it.
Old Oct 25, 2010
WI-JBIRD's Avatar
Yes. The grid shows good continuity. I tested each wire with a multi-tester. Thanks. I'll give that a try. Does the wire go along the driver's side door moulding?
Old Oct 25, 2010
lazlong's Avatar
I think the wire harness is on the passenger's side, I think.
Old Nov 12, 2010
WI-JBIRD's Avatar
OK. I'll be able to look this weekend.
Thanks,
Jay
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
ORskier
May 3, 2015 12:54 PM
Thees1
Apr 14, 2015 08:23 AM
Pir8pete
165
Mar 6, 2009 05:16 PM
