Front Door Speaker Install Help?
Old Oct 7, 2010
ExstInt's Avatar
ExstInt is an unknown quantity at this point
I have a '99 civic ex coupe and i already have the rears installed and i want to run some amped components to the front (i was thinking some polk db6501's).
Does anybody know how hard it is to actually wire through the door boot? I heard people taking wheels, fenders, wheel wells, and all sorts of crap off to get to it. Also, ive searched, but there no good diys about how to do the front door components in a 6th gen. Has anybody had experience or should i take it to the local store, whose gonna charge $175 for just the front speaker install...
Thanks for any help in advance.
Old Oct 17, 2010
gsuchyta's Avatar
gsuchyta is an unknown quantity at this point
Re: Front Door Speaker Install Help?
see if you can't get a clothes hanger through that boot into the car then pull the wire through.
Old Oct 17, 2010
Mad Dog Tannen's Avatar
Tie the new wire to the end of the old one and pull it through.
Old Oct 18, 2010
ExstInt's Avatar
Have you actually done it? cause ive heard the 6th gens have a molex that makes everything unnecessarily difficult. Also, how bad is it to try and put 75W RMS through the stock speaker wiring?
Old Oct 19, 2010
Kennykid2002's Avatar
Kenny the Ricer
Like they said, use a guide wire to guide it through the rubber grommet
I wouldn't advise putting that much power through stock wiring, besides, stock wiring comes through head unit, and i doubt your HU produces that much power
Buy some 18 gauge speaker wire and use those instead
Old Oct 20, 2010
ExstInt's Avatar
i found out theres a molex there for sure and i have power windows and stuff so its going to be a pain to put it through. Is it alright to run wires to the back of the HU from the amp (16 guage), then tap into the wires there, so i only run it through stock wires for 2 feet or so?
Old Oct 20, 2010
Kenny the Ricer
Take a picture of the wires going thru the door, you cant really run wires IN to the HU, its sort of an output only thing :X
Old Oct 21, 2010
ExstInt's Avatar
Sorry, i explained that wrong. I was going to cut the wires where i had to crimp the wiring harness to the stereo harness, and tap into it there. (by behind the HU i meant in the space behind, not actually on the back of it ). I can't take pics cause im at college right now and have no room to pull it apart, but diymobileaudio (which seems to be down at the moment) had pics of someone taking theirs apart and they had pics of the molex and how to drill through it. Someone i talked to said that if you have all power options, the molex will be full so theres no use in even trying to drill through it.
Old Oct 21, 2010
Kenny the Ricer
In theory that could work
I dont know how restrictive those wires would be, though
If it was me, I would rather not waste my time taking apart panels and my deck
I would just drill a hole thru the door panel and run the wire in, then use some silicone seal to seal it in, but thats just me
Old Oct 22, 2010
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
I know everyone says to run new wires as they can't handle the power but I ran a PPI PC2600 @ 2 ohms (300 watts) through stock wiring in my Wrangle powering 2 sets of Boston Pro 6.5s and never had an issue of the amp shutting down or the wiring getting hot. It is such a short run that you will not have any issues with 75 watts.
Old Oct 22, 2010
Kenny the Ricer
It's just that the stock wiring is very restrictive. it will run the speakers, but maybe half the power.
Old Oct 22, 2010
Tigger: I agree there is nothing wrong with running stock wires as long as they don't overheat.
People always make a big deal about what gauge their wires are, and often overdo it. I used solid (hard and not large gauge at all) wire for some of my amp wiring and it works just fine with no overheating. It will still blow the doors off all of my friends stereos that have huge gauge wires on them.
Kenny: It is not going to run at half power period. It may have a little extra resistance but not enough that you could notice in the sound. Overheating would be my only concern.
Old Oct 22, 2010
Kenny the Ricer
At wattage, not voltage
Old Oct 22, 2010
ExstInt's Avatar
Overheating is my main and pretty much only concern. So do you think it would be safer to A)get harnesses and go from amp>rear speaker harness>rear speaker wires>front speaker wires>front speakers or B)wire 16 gauge (i have a bunch of it) from amp to the front speaker wires behind the HU and connect them there.
Old Nov 5, 2010
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
I gotta 6th gen and did clarion component's in the front (I ended up taking them out...long story..) I just took the stock wire that was already routed through the door and just spliced that. I'm running a 1k Watt amp and they were taking about 180 watts, and no overheating occurred whatsoever. When I replaced the speaker with Boston Acoustic SR60's the wire didn't show any signs of overheating or even water damage. The acoustics are running about the same power and no overheating. So I guess the point I am trying to get at is...stock wire's won't overheat =]
Youshoe
May 22, 2015 09:36 PM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
chgofirefighter
Apr 18, 2015 08:08 PM
Thees1
Apr 14, 2015 08:23 AM
doublins
Nov 11, 2001 07:01 PM
