96 Civic Radio Problem
Old Dec 9, 2009
SavageBelief's Avatar
SavageBelief is an unknown quantity at this point
Morning everyone.
I just bought a 96 Civic EX and I have a little problem with the radio. It's an aftermarket Sony that was in there when I bought the car. The problem is the harness. The 12v line from the ignition works fine when the key is in the "ACC" an "ON" positions (checked with a meter) but when I start the motor and the key returns to "ON" there is no power to that line. I'd go through and trace back everything but I'm getting too old to pretzel myself under a dash all day. Thanks for your help.
Old Dec 9, 2009
CraigW's Avatar
Re: 96 Civic Radio Problem
You could check the 12 volt outlet port to see if it has power. ( it should work the same way as the line you are working with) If it has power after starting use it as your source.
Old Dec 9, 2009
Haven't checked that but I will. I thought about connecting it to the constant 12v power for the memory and just shutting off the radio when I turn off the car. What would cause that line to go dead after starting the car though?
Old Dec 9, 2009
CraigW's Avatar
It is possible that the outlet line may be inop as well.
You might try slightly moving the key back and forth a bit once the engine has started and see if the missing voltage trys to return (don't go too far and grind the starter)
I tried having constant power to the audio for a while and it does not work for me... did I turn my stereo off ?? damn. I would try to use the outlet if it works.
Old Dec 10, 2009
Ok, it looks like the ignition is the problem. I twisted the kye slightly forward and lo and behold the radio comes on. So, is the problem in the ignition cylinder? Or is there something else that positions the switch? Another problem I'm having is that ODBII testers can't communicate with my ECM and I think this may be part of the problem so I'd rather get it fixed than jimmy around with alternate wiring.
Old Dec 10, 2009
CraigW's Avatar
You should do a search online for the free 96-00 factory service manual in PDF that is available (I had one on CD and it came up missing)
It will be a huge help to you. I'm not going to venture a guess because I do not know enough about it.
Sounds like you are on the correct path though.
Old Dec 10, 2009
Already have one.
Just thought I'd try and get a quick answer.
Old Dec 10, 2009
CraigW's Avatar
I could not see much looking at the new parts sites, I did find a picture of a white cylinder and some harnesses attached. It looks like it may possibly atttach to the rear portion of the ignition cylinder, I could see a large gauge white wire running up to it from the harness.
Old Dec 10, 2009
That's about all I could find too. I did find a forum that shows how to change one in an Acura from the same year. It looks pretty simple, 3 screws and 2 harnesses.
roverben
Jan 21, 2019 05:16 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
chgofirefighter
Apr 18, 2015 08:08 PM
mugenca
Apr 16, 2015 12:15 AM
