Rear running lights want come on???
Old Oct 10, 2008
93Hondasiboi's Avatar
93Hondasiboi is an unknown quantity at this point
I just got my 93 si HB, It had hids on, they were pulling way to much power, so I removed them and put the stock bulbs back stock, All my fuses are fine but three, IM ether guessing its the main relay or the Alternator.
I tested the main relay top three prongs on it Im guessing are grounds
the four on the bottom of the relay only have fire to three of the prongs on the relay!!!! can sum one point me in the right direction???
Old Oct 10, 2008
Re: Rear running lights want come on???
did you check any fuses?
Old Oct 10, 2008
RallyeRedRider's Avatar
RallyeRedRider has a little shameless behaviour in the past
HID's only draw 35 watts of power. Your regular bulbs draw 55-65 watts of power. ie, if you were having charging problems you just made the problem worse.
Old Oct 10, 2008
except when the hids first power up, they draw over 20 amps and can fry the stock wiring.
Old Oct 10, 2008
What, Really? That's over 240 watts. Even a HO Alternator couldn't keep up, you'd need 2 of them! So if you run HID you really need a deep cell battery, since your draining it every time you turn on the lights?
Old Oct 11, 2008
electric130's Avatar
it's only for about the first 15-30 seconds. after that, they'll pull about 40-45 watts per ballast/bulb. it's 35 watts at the bulb, but no ballast will be 100% efficient. but the high amp draw during startup is long enough to potentially fry your stock wiring. that's why you need a relay harness. it's triggered by your light switch, but the power comes from the battery, so it doesn't burn up your tiny stock wires.
Old Oct 11, 2008
brando54009's Avatar
brando54009 is an unknown quantity at this point
yea hid's dont draw much for power.
did you completly remove the balast for the hid's? if you didn't then that is your problem. also checkj the bulb's and see if they are still find. try replacing then with new ones they should only cost a couple bucks
Old Oct 11, 2008
All the HID stuff has been removed from the car; stock lights are back in. I checked the fuses, and they are fine.. except for 3 of them (2 10 amps, and 1 7.5 amp). I am trying a new main relay tomorrow.
Old Oct 12, 2008
TRIZ's Avatar
^ which fuses went bad?
Old Oct 12, 2008
Their is one 7.5 fuse and two 10 amps that will get no fire. I tried repalcing the relay today but my car wouldn't turn over today!! it gave me a clicking sound !!! i guess its a battery but when i jumped the car off the headlights work but the rear running lights still dont work!!!!
Old Oct 12, 2008
I think the battery is bad or their is something draining the battery down!!!
i removed the amp wiring, hids, and everything looks and seems good!!! their is a dash neon that has burned out comes on some n goes off some????
Old Oct 12, 2008
battery or a short?????
Old Oct 12, 2008
when my car was cranking fine the headlights work, brake lights,and turn singals all work fine!!! but still no rear running lights!!! new fuses n bulbs are in!!!
Old Oct 13, 2008
did you check for power at the sockets? what about ground? (using a meter for both checks)
Old Oct 13, 2008
no power at the rear sockets for the bulbs!!!!
Old Oct 13, 2008
And no power to three fuses on the fuse box ether!!!
Old Oct 13, 2008
CraigW's Avatar
Do the front marker lamps work ??
Cluster and HVAC illumination lighting at night ??
What are the names associated with the fuses you mentioned ??
Old Oct 13, 2008
front markers all work,dash cluster has a neon that comes on and goes off i think its burned out,
Old Oct 13, 2008
CraigW's Avatar
The front markers (parking lights) and the taillights should be on the same fuse (which is o.k. if the fronts are working)
I'm assuming you also are missing your licence plate lights as well ??
You should locate and download one of the free factory service manuals from the web for your model (helps with wire colors, connector locations and such)
You will need to trace back from the trunks taillight wiring forward and find where voltage is being lost.
Old Oct 13, 2008
on the fuse box: sockets 18,19 have no fuses, 20 has a 7.5 fuse in it and is not gettn no fire not even with a 10 amp fuse. socket 10 has no fuse in it ether!!!
car had alarm on it and never worked since i had the car so that stuff is coming out today!!!
Old Oct 13, 2008
Krieger's Avatar
Krieger is an unknown quantity at this point
why are you taking stuff out???
just get a new battery, replace ur fuses, look for a short in ur wires, and get a better alternator.
Old Oct 13, 2008
fixed!!!! Bad ground off of battery and repalced a 10 amp fuse and every thing works!!!
Old Oct 26, 2008
laurenl's Avatar
laurenl is an unknown quantity at this point
That is really cool.
Old Nov 4, 2008
Now all i need now is a new sunroof glass lol and a new body kit lol
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
NukeSilo
Nov 20, 2001 05:17 PM
cazminn
Nov 9, 2001 11:18 AM
