Inverted HID Kit
Old May 14, 2008
Munck's Avatar
Munck is an unknown quantity at this point
Inverted HID Kit
Hi all,
I'm new to this forum, and I hope to get all my question about my Civic answered!.
Please be patient with me, Iīm kind of new with Hondas...
Well, letīs get to the point:
Iīve installed a low beam HID Kit, but I think somethingīs wrong.
The Hi beam is the xenon lights, and the low beam is the Halogen lights.
I canīt figure out whatīs wrong....
If this is a repost, sorry
Thanks for all the help!
Old May 15, 2008
pheaton's Avatar
A descendant of 2k1civic.com
Re: Inverted HID Kit
That's weird, how did that happen? You have a 2000 right? There is only 1 bulb for highs and lows. Which kit did you buy?
Old May 15, 2008
i think you wired it wrong. our headlight wiring is a bit confusing and the way it works, you have one wire thats 12v+ all the time, then for the low beam the LO wire becomes ground, and for the hi beam the HI wire becomes ground. otherwise they stay hot so the light is off.
Old May 16, 2008
Munck's Avatar
Yep, I have a 2000....
Thanks for the help, people!
Iīll try to review the wiring, then iīll post the results here...
Phaeton, I bought a H4 8000k HID kit...
Thanks!
Old May 16, 2008
chances are, you just have to switch around the wires. its just hooked up in reverse. you need to first find out which of the three wires for each side is the constant 12v wire (always hot in both lo beam and hi beam mode). then figure out the other two wires. its hard to explain but for them, they will both be hot when headlights are off, and when lo beam is used, one will turn into a ground so the lo beam lights up (power from 12v wire and ground from other wire). when hi beam is used, the second wire turns ground and the first wire stays hot so the lo beam turns off and hi beam comes on.
UltraHDGames
Jun 8, 2016 05:16 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
ktae13
Electrical
Sep 26, 2015 05:14 PM
