subs not working right amp wire help
Old Apr 7, 2008
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
Okay So i need some help. I have an alpine headunit, Infinity Speakers, Infinity amp, 2 12" Kicker Comp CVRs subs.
Okay Now I have a 4 chan infinity amp. I have my 4 speakers/ 2 subs powered off it. Yes I know I need to get a Mono amp which I am soon.
now, I had 50ft of orange extention cord running through my car (seen in pics) I forgot how my amp was wired. Todd (XXchiovdaxx) or whatever on here wired it up for me and it bumped hard.
So yeah I replaced the cord with some nice wire hooked it all up speakers sound good, but the sub doesnt work right. take a look at the pic on how i have it wired. What's wrong here? I took the 2 chan dedicated to 4 speakers. I put the 2 (-) wires together and the 2 (+) wires together.
Now for the subs. I have them both wired so I have one chan for one sub and the other chan for the other.
So why does it not sound right? When I put the RCA in the amp for the SUBS when i put both of them (white and red) nothing really happens. When I put only ONE (doesnt matter the color) in its got bass. But it's not as loud as it was.
So what's wrong here????????? ughhh
BEFORE:
AFTER:
Old Apr 7, 2008
ArrizX's Avatar
ArrizX is an unknown quantity at this point
Re: subs not working right amp wire help
Seriously, an extension cord? Thats just not safe. If you're going to have a system like this, use the proper wiring.
My first and overall advice is to un hook it all as its seemingly unsafe, and take it to a licensed installer before a fire starts.
It was hard to follow, but just looking at your pictures, you need to plug in that left input for the rear channel.
Old Apr 7, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
wow.....wow.....wow......wow.....wow......
You need a warning sticker on your passenger door that says, "Enter at own risk." Make sure there are visible skulls and crossed bones for those that may be unaware of the dangers posed by your electrical knowledge.
The orange wires in your first picture, you said they're gone right? Please also remove any other electrical tape you have in your system and replace it with solder and heat shrink tubing. It is much safer.
For safety reasons, please close off any exposed wires including the silver wire below the speaker wire and the blue battery wire mushrooming itself out of the amp.
How many ohms does your amplifier support?
How many ohms do your subs support?
Which type of competition are your subs made for?
How many ohms are you running in your current setup?
Are you set up for sequence or parallel?
You need a new amplifier.
You also need one of these:
Old Apr 7, 2008
Maple50175's Avatar
lol seriosuly yes. When i plug that white left rca in the sub hardly works.. it's totally weird. IDK how my friend had it setup. and im in NC away from home so he can't see it ughh
Old Apr 7, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
if i had to guess, your subs are wired wrong. the wiring for one is canceling the other. it's not that their out of phase, but your wiring is just wrong. disconnect your sub wires and connect them one at a time.
then again, it sounds like you might just be over-driving that amp...we're gonna need a little more info on your setup, but my advice is to disconnect everything you have and start from scratch. something is def wrong if all you did is replace the electrical cord with real speaker wire...
Old Apr 7, 2008
Maple50175's Avatar
Well see here is what I don't know. the subs came in a box at 2ohms, my friend wired them so that id have wires from each sub so its 4ohms or something.
The amp stats are:
Features:
o 4-Channel Car Audio Power Amplifier
o 111 Watts RMS x 4-Channel @ 4-Ohms and <1%THD+N
o Signal-to-Noise Ratio : 81dBA (1W/4-Ohms)
o 139 Watts RMS x 4-Channel @ 2-Ohms (14.4V Supply and <1%THD+N)
o 278 Watts RMS x 2-Channel @ 4-Ohms (14.4V Supply and <1%THD+N)
o Dynamic Power : 164 Watts @ 2-Ohms
o Effective Damping Factor : 6.315 @ 4-Ohms
o Frequency Response : 10Hz~100kHz (-3dB)
o Maximum Input Signal : 5.5V
o Maximum Sensitivity : 75mV
o Output Regulation : .088dB @ 4-Ohms
o Dimensions (WxHxD) : 16-3/8" x 2-11/16" x 12-1/8"
the subs stats are:
* Woofer Size (inches) 12 x 2
* Woofer Material Inject molded poly
* Enclosure Type Ported
* Color Gray
* Pieces in System 1
* Width (inches) 32-3/4
* Height (inches) 16-1/4
* Depth (inches) 17-1/2
* Second Depth (inches) 14-1/4
* Connector Type Spring post
* Power Range (Watts RMS) 50-600
* Maximum Wattage 1200
* Sensitivity 98 dB
* Impedance 2 ohms
As you can see the wire comming out of the port hole on the subs.. so that makes 4ohms right?
help lol
Old Apr 7, 2008
Maple50175's Avatar
o **** how far are u from Hickory, NC? Thats where I am lol Wanna check it out? for me lol
Old Apr 8, 2008
no, I live in Raeford, but I am in Arizona at the moment. looks like you're still out of luck.
Old Apr 8, 2008
DeX's Avatar
DeX
Canadian, Eh!
Try flipping the amplifier from stereo to mono.
Old May 13, 2008
BOLIANDO's Avatar
BOLIANDO is on a distinguished road
what you need to do is take everything out . rewire it from ground up the right way.
Old May 13, 2008
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Yeah in the industry that's what we like to call "a total re-do".
Old May 15, 2008
electric130's Avatar
dude, i'm in stanley/lowesville/denver, NC area. i'll get you straight in July if you want.
Old May 15, 2008
WgnrNick's Avatar
WgnrNick will become famous soon enoughWgnrNick will become famous soon enough
Take it somewhere and get them to do it before your car bursts into flames... wow... ha.
Wagner
roverben
Jan 21, 2019 05:16 PM
ORskier
May 3, 2015 12:54 PM
0100010
Dec 1, 2001 03:27 PM
CivicLX2001
Nov 16, 2001 06:33 PM
mohawkboom
Nov 2, 2001 06:00 PM
