Missing from the get go!
Old Sep 13, 2007
civic_prime's Avatar
civic_prime is an unknown quantity at this point
Angry Missing from the get go!
I've got a '96 civic and has been sputtering for a week. I did the basic tune-up, cap,rotor, wires, plugs. also put in a new O2 sensor. Still to no avail this problem is pssing me off. anyone else had this problem? if you say check for a vacuum leak, already did that. fuel pressure? got it. injectors? they work. the only thing i can thin of is the ignition module.
Old Sep 13, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
Re: Missing from the get go!
clean out the MAP sensor and basically any sensor hooked to the throttle body. clean out the TB too
Old Sep 15, 2007
Everything's clean as a whistle, but still missing.
Old Sep 15, 2007
check the IAC valve bolted to throttle body or fast idle thermo valve if you have it? thats usually why car wont idle, cause its clogged up and not allowing air to pass around the closed TB flap.
juicetayne
Sep 30, 2015 11:02 AM
Bruce2
Sep 27, 2015 08:45 PM
NROD315
Sep 4, 2015 09:22 PM
