chassis to door wiring loom problem! pic inside
hopefully this is speaks for itself.
before, when i would open the door, the speaker would cut off, so i knew there was a wire that needed to be repaired.
the control for the power lock on the passenger side had gone out a while ago too.(still worked on this one surprisingly)
i got a new power window assembly because i trashed the otherone because it kept coming off the track and i tore it up. so i attempt to test the new unit before installing it and it wouldnt work. i fiddled with the wrapped wiring loom and hear some sparking noises and today i finally take a look inside and see its much worse than i expected.
honda wants about $80 for a replacement piece and i thought id be able to repair the original myself but it looks like i might be better off replacing the whole thing.
is there anywhere i could maybe find a better price? i checked ebay, nothing there that i could find. this wiring assembly goes pretty far into the car also, more than i had originally anticipated, but it shouldnt be a problem swithing it out if i can find it for a good price.
(the wires that are there are pretty brittle by the way, hence why i think i should just change it out. some that have not broken are on their way.)
Re: chassis to door wiring loom problem! pic inside
Do you have any aftermarkey wiring ran through the harness for the speakers? What kind model car is that? I know when I was running 16 awg through the molex like that was a pain in the **** because it was so hard to reach... Mines a 99' Civic Ex
its a 96 ex coupe.
all original wiring.
do you think this is salvagable? how do i get the crimped pins out of the plastic without totally destroying it all and is there a diagram somewhere that would show which wire goes where?
this would probly save me lots of money to "fix" it myself..
^you beat me to it, triz.
definitely check there, majestic's prices are a hella lot lower than anyone elses.
MamaBear2015
May 3, 2015 02:17 PM
