Best Wheel Size For Flush Look
Old 05-03-2018
JesusWoreNikes's Avatar
JesusWoreNikes is an unknown quantity at this point
I don’t know anything about offset, all I know is I want the biggest wheel with out the possibility of rubbing or my tire blowing out on the freeway. Maybe something like these pics.
Old 05-03-2018
Prelude Owner
GolNat's Avatar
Re: Best Wheel Size For Flush Look
Start surfing wheel threads and checking wheel specs.
Look for a wheel offset calculator online and compare wheels.
Measure from where the current tire is out to where you want the wheel to sit. Google has info on how to do this. Fender rolling is required if you want to get super flush along with tire stretching.
Old 05-03-2018
Thanks man, after searching I think a tire size of 205/45R17 and a wheel size of 17x7.5 with a 40mm Offset will look good. Any thoughts?
Old 05-03-2018
Prelude Owner
GolNat's Avatar
I didn't have a 6th gen so I can not confirm if it will give you the look that you want but you can always add spacers to make up any space that is left.
I ran 17's on my 7th gen and I went with 205/40/17 to keep it closer to stock rolling diameter. Use this calculator to pick a tire size that is closest to stock rolling diameter as possible. Of course you can run a smaller or larger size if you want.
https://www.tacomaworld.com/tirecalc
Is the car lowered?
Old 05-03-2018
Is the car lowered?
Yeah I lowered it but I don’t know how much, here’s a picture though. I have coilovers so I could rise it if it rubs.
Old 05-03-2018
Prelude Owner
GolNat's Avatar
I don't know why the forum ghosted your posts but its fixed and duplicates deleted.
Perfect, coilovers are going to be what you want so you can dial in the exact look you are going for. Only other thing is camber adjustment and I am not familiar with how it works on a 6th gen.
Old 05-03-2018
Thanks man, Helped me out a lot. I think I should be good to go.
Old 05-03-2018
Is the car lowered?
I think I’ll run 205/40/17 too
brianna12
Transmission DIY
18
12-01-2019 04:40 AM
brianna12
08-26-2012 10:45 PM
austin165
22
07-24-2012 09:11 PM
Chris4895
08-31-2011 05:29 AM
slh1000
10-28-2007 02:24 PM
Quick Reply: Best Wheel Size For Flush Look
