Brake scraping? Or something deeper
Old Oct 23, 2018
Stock2000ek's Avatar
Stock2000ex
Stock2000ek is an unknown quantity at this point
So this month my 2000 civic sedan started making a periodic scraping sound whenever i brake and my speed starts dropping below 30 km/h got a full brake job done bc i needed fronts as well but i also asked them to check the wheel bearings which they said were fine,, but its almost like something is warped or i dont even know,, basically when ever the speed drops below 30km a scraping sound can be heard from the passenger rear side and as the speed continually drops so does the frequency of the scrapes,, i would just rather not spend more money before knowing what the problem is, thanks guys
Old Oct 23, 2018
Colin42's Avatar
Re: Brake scraping? Or something deeper
Pop the drums off and have a look, might need cleaning/servicing, could also be slightly warped
Old Oct 23, 2018
Stock2000ex
Sorry should have added that pads rotors calipers drums and pads were all changed yesterday drove it today, still got the scraping,, im going back, but i just wanna know if it could be a bearing, axle bearing, bushings, or if it is forsure the brakes bc it only happens during braking
Old Oct 23, 2018
Colin42's Avatar
Sounds like a dust shield may be tweaked in the front but you were saying you heard it in the rear. Made me think that something is up with the drums. Maybe not adjusted right?
Even brand new parts can be warped right out of the box, happened twice in a row with some rotors for my mom's car, stepped up to a better rotor and had no more problems
Old Oct 23, 2018
Stock2000ex
Oh okay thanks, ill pull some stuff off n havr a look to see if i can see any physical scrape marks anywhere then ill head back
ravolutionazx
Brakes
Oct 6, 2022 05:31 PM
Thaik
May 30, 2016 05:12 PM
dem0nk1d
Aug 9, 2014 05:35 PM
mdawg
Wheels and Tires
Apr 30, 2007 09:36 PM
ducksause
Oct 25, 2002 01:55 AM
