Cars not running right
Old Sep 14, 2018
Codyfoster2003's Avatar
Codyfoster2003 is an unknown quantity at this point
I have a d16y7 it’s been sputtering under acceleration for about a month I replace the plugs nothing changed the other night from the stop light my idle jumped to about 1,100 and when I hit the gas to go it limited to 1,500 till I went to half throttle I cleaned the iacv and replaced the the spark plug gaskets in the valve cover no fix any ideas?
Old Sep 15, 2018
Wankenstein's Avatar
Re: Cars not running right
Clean the throttle body
Check the throttle body cable for proper tension
Check distributor coil arc per ezone method
Check mechanical (cam/crank) timing
Check valve clearances
Old Sep 15, 2018
If you have this situation, plugs AND wires MUST be replaced at the same time.
Old Sep 16, 2018
RayfenWindspear's Avatar
RayfenWindspear is an unknown quantity at this point
In my experience, plugs and wires should ALWAYS be replaced at the same time. Tried both ways.... never again.
FrozenCaveman
Mar 11, 2014 02:21 PM
CivicRage
20
May 3, 2010 07:02 AM
nickr
Feb 15, 2010 12:31 PM
back2black
Jun 10, 2009 07:19 AM
jmnbv123
Jul 30, 2007 09:55 AM
