Help engine bogging
Old Aug 19, 2018
newGuyneedHelp's Avatar
newGuyneedHelp is an unknown quantity at this point
Help engine bogging
I just recently bought a 2000 ek civic coupe it is a 5 speed, yes it’s a hoopty, has CEL on and at first when i tap the gas to get her moving it is fine and very responsive.. it shifts hard but goes through all gears like it should+ reverse. Anyways the car is very peppy when you tap the gas, but when you push farther down on the pedal it seems to bog out, and accelerates very slow.. what could be the reason and how can i fix it??? i’m New THANKS
Old Aug 20, 2018
Colin42's Avatar
Re: Help engine bogging
scan the car and post the code numbers Pxxxx format
Intake or exhaust could be restricted
Old Aug 21, 2018
Engine bog or bad tranny??
Ran the codes, Came up P0500, Vehicle speed sensor malfunction.. explains why the speedo doesn’t work. Easy fix?
Old Aug 22, 2018
Wankenstein's Avatar
Pull genuine (oem) from junkyard. Bring current one with you to match up. Transmission dependent and will need to match up the gear teeth direction. Don't buy aftermarket...they blow.
The issue could be something else besides the sensor but it's a cheap place to start $10-$15 at junkyard. Or, just pocket change (uh, keep in your pocket and oops! I forgot to pay for this...wink wink..lol).
Old Aug 22, 2018
the sensor teeth themselves were all good but there was a lot of corrosion on the top of the sensor and inside of the connector:/ should i get new sensor and connecter? or can the corrosion be cleaned(it’s literally covered in blue gunk)
Old Aug 22, 2018
Yea get it all. Splice good connector to harness and the splices had better be absolutely waterproof when you are done.
Timbob
Jul 31, 2018 09:18 PM
islametco
Mar 1, 2013 04:52 PM
Wellthereugo
Jun 4, 2011 03:53 PM
gearbox
Sep 10, 2005 08:55 AM
kennisonxgs
Interior
May 8, 2003 04:04 PM
