Does this pop off?
Old Aug 8, 2018
prr's Avatar
prr
prr is an unknown quantity at this point
Does this pop off?
I need to replace the hatchback lift supports for my Civic. I found some @ Rockauto (http://www.monroe.com/en-US/e-catalog/901471/ is for one side).
My question is--the part that is on the left side of the picture (from the monroe.com site), that has holes for screws--it is screwed onto the frame of the car underneath black plastic trim. I took two pics, you can see them here.
My quesition is--does this black plastic trim pop off, or do I need a special tool to take it off--and will it snap back on? The white lines in the second pic are the conductor element in the rear windshield.
ID:	112430   Click image for larger version
Old Aug 8, 2018
Re: Does this pop off?
There's probably a U shaped metal band wrapped around the end that grips the ball on the stud.
Use a pocket screwdriver to lift that U shaped clip out a ways, and the end of the strut should then just come right off the stud.
Make sure the tailgate is supported, don't mash your head.
Old Aug 9, 2018
prr's Avatar
prr
OK I'll go look today or tomorrow.
Yeah, gotta be careful about the head mashing part. That could ruin an entire day.
Thanks for the tip on how to handle this. I might have just let it slide, but one day wife & kids borrowed my Civic, and I forgot to tell them about it. It was an unpleasant surprise, but seriously a problem like this really could hurt someone, so I need to get it fixed.
Old Aug 14, 2018
prr's Avatar
prr
post deleted (double post)
Old Aug 14, 2018
prr's Avatar
prr
I didn't realize until I went out and looked at it, and then saw this video, that you were talking about the lift support itself, instead of the trim like I was talking about in the OP. (
Old Aug 14, 2018
Colin42's Avatar
just pry carefully from different sides, one side will move the most start popping it off from that point
Old Aug 14, 2018
I couldn't see what you're dealing with, I assumed the struts would pop right out without having to deal with any trims.
I haven't had to do much to cars that old in a long time LOL
Old Aug 14, 2018
prr's Avatar
prr
I was able to pop them off quickly when I saw in a video what you were talking about.
Hey this car is an oldie but goodie. Apart from this lift support issue I'm working on now, the last time I had a non-routine maintenance item need to be fixed on this car was 2012, when my mechanic fixed a leaking seal when he did the timing belt. You could call that maintenance if you wanted, I don't know. At some point (before or after 2012, I forget) he replaced an electronic part in my transmission for a couple hundred bucks. Since then, its only been brakes, batteries, tires, oil & coolant drains. I'm loving it!
Old Aug 15, 2018
prr's Avatar
prr
OK the new set is scheduled to arrive on Friday.
I went out today to remove the old pair, which I was able to do with your technique of pulling that u clip back a bit.
OK now, just look at this picture:
It is clear that the end on teh right side, is what attaches to the frame of the car, so to speak. The end on the left side is what attaches to the hatchback itself.
But the end on the left side of the picture, I'm not sure about. Will I be able to pull the support off that end (by pulling on the u clip), and then simply attaching the new lift support (without the end on the left)? Or is this going to be a lot more complicated.... ?
Old Aug 15, 2018
I suppose you will find out when you can see the new unit in person.
Old Aug 15, 2018
prr's Avatar
prr
OK I'll take a look when I get it.
Old Aug 18, 2018
prr's Avatar
prr
As it turns out, I had to install the new ones by screwing in the bracket--there was no ball & socket with a uclip. Oh well it was just a thought I had. Its all done now, thanks as always for your comments.
prr
Detailing
May 21, 2018 02:48 PM
digital808
May 14, 2012 03:20 PM
MegaHurtz
Apr 13, 2004 12:57 AM
Marcus
Sep 1, 2003 12:32 PM
