Name of this plastic clip
Old Jun 10, 2018
prr's Avatar
prr
prr is an unknown quantity at this point
The last couple of days, I have heard a strange new tap-tap-tap sound coming from the engine, that is very intermittent--most of the time I don't hear it at all, then I hear it for 5-10 seconds, then it disappears for a couple of days. I popped the hood and think I found the culprit--a plastic clip that holds a hose has become detached from the base. I have circled in red the clips. The red lines are not wide in the thumbnails, but if you open the pics, you can see the red lines. I forget which one came loose, but there are 3-4 in a series along this one hose, and one of them is loose.
Can someone tell me what the name of this is, so I can order one?
ID:	112317   Click image for larger version
Old Jun 10, 2018
Re: Name of this plastic clip
That's a wire harness, not a hose. Even if the clip popped out or was ripped out, it probably wouldn't make noise.
Before sweating it, you could secure it to the body with duct tape first to prove that's your noise.
Old Jun 10, 2018
prr's Avatar
prr
Fair enough, I'll try that to make sure.
SenorAlejandro
Feb 17, 2013 08:53 PM
srfdog88
Dec 10, 2002 11:27 PM
Slvr2k2
May 18, 2002 04:19 PM
RedDragon333
May 7, 2002 05:08 PM
Dustman380
Apr 21, 2002 02:27 AM
