Alternator dead - How hard to replace?
Old Apr 13, 2018
Slicer1989's Avatar
Slicer1989 is an unknown quantity at this point
The alternator on my 99 Civic finally gave up the ghost on me.. So gonna replace it tomorrow. I watched some videos online and it looks like there is a VERY common issue of the one bolt getting stuck and needing to be drilled / beaten out.
How hard is it to replace these? looks like it's in a bastard location... Some people say you can go out from the top, other says the bottom. Which is easiest / best?
Old Apr 14, 2018
oneheadlight's Avatar
oneheadlight is an unknown quantity at this point
Re: Alternator dead - How hard to replace?
when I did mine it was from the bottom that I removed/installed. The one bolt wasn't too bad, soaked it in kroil penetrating oil. then tapped it out. Was a long process of installation but not complicated. Take your time and you'll be good.
curious.. how many miles did you get on that alternator? is it stock? (mitsubishi)
Old Apr 14, 2018
Slicer1989's Avatar
I'm not sure if it ever been replaced or not... but the car has 233k miles on it. The one bolt was stuck on, so we had to cut it off... But it's replaced now - If it weren't for the bolt, it wouldn't have taken long at all.
Old Apr 16, 2018
Talking Re: Alternator dead - How hard to replace?
hey thanks for the info.. yeah sounds like the original. Mine lasted until about 200k. It failed because of sloppy work by some mechanic who damaged the mounting bolt. The replacement (TYC) actually came with a test report that shows it puts out more amps at lower rpms than the factory! nice! But I did order two, got one from china and one from taiwan. The taiwan was much better quality so I kept that one. been working well for 5 years now.
glad you got yours replaced!
FurBall
Dec 28, 2008 08:03 PM
skiboard
Ottawa
27
Apr 22, 2005 12:28 PM
ASIANPRIDE
Jan 14, 2004 04:19 PM
