Best radiator
Best radiator
Hey guys, my radiator is cracked and I’m gonna have to replace it so I’m just lookin for the best bang for my buck. I wanna stay cheap but I want to also keep quality as I am soon to throw a turbo setup on it. A few choices would be awesome! Thanks guys!
Re: Best radiator
Re: Best radiator
Mishimoto:
https://www.amazon.com/Mishimoto-MMRAD-CIV-92-Transmission-Performance-Aluminium/dp/B001EQ7S2C/ref=sr_1_6?s=automotive&ie=UTF8&qid=1515705048&vehicle=1999-59-752-191--7--5-5753-1442-1-1-1640--1-0&sr=1-6&ymm=1999%3Ahonda%3Acivic
You didn't post your car's model or transmission type so you will need to make sure you input those correctly before ordering. Also, make sure they put the correct psi cap on it for your car's engine.
Koyo and TYC (both made in china) seem to come up a lot as an affordable ($50) single core with plastic top and bottom radiator.
If it were me I'd pull a used Honda OEM from a local junkyard for $20, carefully pressure wash it (avoid bending fins), do first fill and bleed with distilled water, drive it around for a while, return and inspect for leaks. If all is good then do another drain/fill/bleed with Pentosin Pentofrost A3 (blue) 50/50 coolant mix.
Re: Best radiator
cheap and quality rarely go hand in hand, denso is the oe part so if you're looking for a simple replacement go with denso, you can order it online and probably save a bit. if you want a 'performance/racing/rice/cool-looking' rad go with the mishimoto one Dong posted
Re: Best radiator
In most cases I would go with a used, known working Honda OE/OEM part versus just about any new aftermarket part of the same replacement. Besides, many of the "new" parts sold at parts store are just remanufactured/refurbished.
cyprosoft
Nov 6, 2017 02:41 PM
Civic_Nightmare
Sep 8, 2011 12:16 AM
ImPulse
Feb 21, 2005 11:12 AM
netcbc
Apr 10, 2002 10:10 PM
