p0141 replaced the o2 sensor still code
Old Dec 18, 2017
Alex519's Avatar
Alex519 is an unknown quantity at this point
Hi I have a 1999 honda civic dx with a d16y8 head and ecu I keep getting code p0141 I replaced o2 sensor three times replace the catalytic Converter as well and still it's throwing the code hell I went as far to replace the damn ECU in hopes that was the problem and so far no solution anyone ever run into this problem I looked online and it said that it could be from a bad ground where would the ground be? also I know the 02 Sensor has to reach a certain temp and I think it is because my car does run fine just the very small occasional hesitations it happens so rare if I sold the car to someone they wouldn't even know but please if you have the answer help a brotha out!
Old Dec 18, 2017
GolNat's Avatar
Prelude Owner
Re: p0141 replaced the o2 sensor still code
Did you use the correct sensor. The people behind the parts counters at AZ and PB like to say “universal” ones will work but they don’t.
You may have installed one without a heater circuit.
Old Dec 18, 2017
Alex519's Avatar
Yes I done denso and still got it it comes right back on but the vehicle runs fine a skip hear or there in the acceleration every once in a while
Old Dec 21, 2017
Wankenstein's Avatar
Please read: http://troubleshootmyvehicle.com/hon...ygen-sensors-3
elpasovatoloco
Oct 13, 2013 09:35 PM
2004CivicVP
Apr 17, 2012 09:00 PM
02civicboy
Dec 10, 2011 01:40 PM
ricerchick
Oct 18, 2011 01:11 PM
butler89sir
Aug 7, 2010 10:13 PM
