2000 Civic LX cruise control not working
Old Nov 11, 2017
MamaBear2015's Avatar
MamaBear2015 is an unknown quantity at this point
The dash button turns on the light inside it and that's it. Nothing else about the CC works.
How difficult is troubleshooting this myself? I'm not a mechanic but am a former electronics technician and have a meter, for example.
Is there a troubleshooting chart somewhere, and a layout diagram of where everything is?
Old Nov 12, 2017
old97civic's Avatar
old97civic is an unknown quantity at this point
Re: 2000 Civic LX cruise control not working
Can you download the manual? It's easy to find online.
Here's a link to someone's cloud storage that's still valid:
https://docs.google.com/open?id=0B_O...c0NTY0MzZmMzMz
Look at p. 23-240 and around there. The CC works off vacuum so if any of the hoses are broken/disconnected etc that could be the problem as well.
Old Nov 12, 2017
Got it, and will take a look. Thanks!
Looks pretty complicated. Should have my mechanic do it.
Old Nov 12, 2017
Does the car have manual transmission or automatic?
If manual, see if the rubber button is missing from the clutch pedal switch contact tab (the lower switch)...If it's missing, the pedal may no longer push the plunger of the switch in.
Same for the brake pedal switch, but most of the time people notice the brake lights stay on and it kills the battery.
Most of the electrical testing can be done from the cruise control unit connector under the dash.
Old Nov 12, 2017
Automatic.
That happened a few weeks ago on our 2002 Civic. First the transmission started slipping a little, when starting out, then the battery was completely dead outside a restaurant. We got a jump start and took it to the mechanic, thinking the battery was bad. But it was a crapped out piece of plastic in the brake pedal and the brake lights were on all the time. He replaced it and it was fine!
Hmm.
