Thread sealent when re-installing engine drain plug?
Old Aug 16, 2016
prr's Avatar
prr
prr is an unknown quantity at this point
I saw a video on changing coolant, that suggested using a product from a tube called thread sealant, when reinstalling the engine drain bolt/plug after draining the coolant. Is this something that would really make a difference? Is there much of a threat of coolant leaking out if I don't (or whatever other reason for applying the thread sealant)?
Old Aug 16, 2016
Re: Thread sealent when re-installing engine drain plug?
It uses a crush washer, no need for thread sealant.
The threads are not designed to seal.
That crush washer does the sealing.
You have to get it tight enough to crush in order for it to actually do its job though.
And like I mentioned in the other thread, I do use RTV on that crush washer just because it's 'cheap insurance' against leakage.
Old Aug 17, 2016
prr's Avatar
prr
Great. One less thing I have to buy and think about.
Thanks.
Timbogates
Mar 14, 2016 09:14 PM
Jan 27, 2016 10:20 PM
byzelo
Jan 17, 2016 07:34 PM
FxckWil
Dec 21, 2015 10:25 AM
mikey1
Dec 9, 2015 12:44 PM
