Is my knock sensor broken?
Old May 30, 2016
fvckbg's Avatar
fvckbg is an unknown quantity at this point
[IMG]
Is it broken? If not I can't get it to plug in. What happens if I leave it unplugged?
Old May 30, 2016
Re: Is my knock sensor broken?
That's broken.
Probably will set fault code P0325 until it's fixed
Old May 30, 2016
fvckbg's Avatar
Originally Posted by ezone
That's broken.
aw damn. Are the eBay ones good? I'm not tryna spend $100 on a new sensor. Also how would I wire it?
Old May 30, 2016
No comment.
Why would you have to "wire it"?
Unplug the harness connector from the broken shell you were holding (separate the gray connector from the blue chunk of broken plastic), install the new (correct) sensor, plug in the wire connector.
Simple.
Old May 30, 2016
fvckbg's Avatar
No comment.
Simple.
oh I thought I had to buy the part where the wire connects to. Thanks.
supersnake83
May 30, 2016 06:34 PM
supersnake83
May 23, 2016 07:43 PM
Bauxite
May 18, 2016 11:56 PM
maddjv926
May 11, 2016 07:54 PM
Alegations80
May 1, 2016 02:33 PM
