Crankshaft pulley bolt removal help
Old May 27, 2016
fvckbg's Avatar
fvckbg is an unknown quantity at this point
Hey guys Im changing out my timing belt for a 98 civic ex. Everything I've done so far was remove the p/s out the way and the belt, took out the alternator belt and the a/c belt too. Also I believe I aligned the timing belt to tdc. I tried rotating the crankshaft bolt counterclockwise but the timing belt isn't moving anymore so I guess it's on tdc cause the word up is on the tdc. My only problem as of now is the crankshaft itself. The bolt is a pain in the ***. I'm using 2 breaker bars to take it off but it's not working. I don't have a impact tool or anything. Any tips guys?
Old May 27, 2016
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: Crankshaft pulley bolt removal help
Can you wedge one breaker bar onto a jack or jack stand and then get a long extension pipe to put on the other breaker bar.
On my 02 I used a 6ft fence post and slid it over the breaker bar to get enough leverage.
Old May 27, 2016
Do you have the crank pulley holding tool?
Borrow the crank pulley holding tool from dangerzone? (or similar)
Old May 27, 2016
fvckbg's Avatar
yea that's exactly what I'm doing with the jack stand and it's still not working. I tried jumping on the extension bar, sitting on it and nothing. It's on there good I'm going to give it another go tomorrow.
Old May 27, 2016
fvckbg's Avatar
yea I'm using that and it sucks cause it keeps sliding out
Old May 27, 2016
When I use that tool, the breaker bar I have holding it is braced up against either the ground or a control arm. Otherwise, that **** wouldn't break loose
Old May 28, 2016
TS2008's Avatar
TS2008 is an unknown quantity at this point
Try this:
Block your Honda tool for movement with a long nose vise grip
and than Attach a 6' barbell to your brakerbar
piece of cake even a girl has enough force to lose this bolts.
Last edited by TS2008; May 28, 2016 at 01:12 AM. Reason: add more detail and resize images
Old May 28, 2016
mikey1's Avatar
go to a "big box" store / home depot etc, and buy yourself a 6 feet steel pipe from the plumbing section, put it over the breaker bar, thats how i do it
Old May 30, 2016
old97civic's Avatar
old97civic is an unknown quantity at this point
Anyone ever broken off the head of the crankshaft bolt? That would certainly be a bad day?
Old May 30, 2016
mikey1's Avatar
no but i have heard stories of people breaking off the end of the crankshaft from over tightening that bolt, the crank is probably weaker then the bolt and would break or strip first,
last time i took it off it made a noise so loud i thought i broke the socket, but didnt, it was just the bolt snapping loose
Old Jun 4, 2016
Wankenstein's Avatar
Gain 100 pounds immediately and stand on extension pipe/breaker bar. Get a fat friend to come over and sit on it while you push or stand on it too. You can try spraying some PB blaster on it and let it sit overnight..might help some.
Axle and cranks bolts are no challenge for this (me) Sasquatch.
05Ep3k20si
Electrical
Nov 6, 2015 04:26 PM
ilgnay
Apr 26, 2010 11:53 PM
Unleaded
Jun 26, 2007 09:25 PM
Dreamer01
Detailing
Dec 22, 2001 10:17 AM
onelifetolive
Bolt-on Engine Performance
Nov 10, 2001 10:58 AM
