Skunk2 y7 idle issue
Old May 10, 2016
febosy7's Avatar
febosy7 is an unknown quantity at this point
Exclamation Skunk2 y7 idle issue
I NEED HELP!! I have a stock d16y7 MT. I recently added a Skunk2 D series IM with a SK2 68mm TB. I took off the SK2 TB bc it would not let go past 2000rpms at first. The only way it would was with switching the MAP and TPS wires but the car would turn off on me when turning plus was right connections. I had a 95 TB laying around and put that on. It has worked the best compare to stock or sk2 TB. The problem now is that it will not maintain an idle. As soon as i start the car or begin to slow down it starts making this idle searching noise going up and down between 1500-2000 rpms. probably not the best way to describe but hopefully its something you guys have encounter before. This is my first honda i ve worked on but i am certain i ve got everything hooked up right. i keep getting P1509 code. I called skunk2 and all they say is i need to tune it. which i know i do and eventually i will but i know theres gotta be a fix meanwhile. I would love to be able to put on the SK2 TB but if not at least be able to fix the IM with OEM TB.
Turtle530
Feb 17, 2016 09:57 PM
jedo
Mid Atlantic
Aug 8, 2003 07:54 PM
ElEvEnTyMeS
Mar 21, 2003 12:29 PM
Hwoody77
Mid Atlantic
Nov 19, 2002 07:17 AM
Desi
Feb 13, 2002 09:36 PM
