Motor mount issue
Old Apr 23, 2016
Erobair93's Avatar
Erobair93 is an unknown quantity at this point
Motor mount issue
So my passenger upper mount broke also the bracket from the mount to the transmission broke. Thats not the big problem the problem is the one of the bolts on the transmission to the bracket broke. Upon further inspection they are studs and are not coming out. How would i fix this?
Old Apr 23, 2016
mac25's Avatar
Dr Krieger of Modification
Re: Motor mount issue
***Warning: I have no practical experience with this***
That being said, I would imagine that the bolt in question is threaded into the transmission,and, that using a "bolt extractor kit" would work to remove it.
Old Apr 24, 2016
Wankenstein's Avatar
Can use the tool Mac posted:http://www.harborfreight.com/Screw-E...-Pc-61981.html
or a reverse (left hand) drill bit: http://www.harborfreight.com/left-ha...-pc-61686.html
Research on line and find out which one is better for your application. The screw extractor set that Mac posted looks like it's better geared towards your car's situation. I've used a left hand bit to remove a broken valve cover bolt but, they're only 8 mm's. Also, though I linked Harbor Freight's items you may want to consider checking around for possibly higher quality bits.
dsm482
26
Apr 7, 2016 10:32 PM
boombaby31
Apr 5, 2016 12:48 PM
Scotty13
Apr 3, 2016 07:46 PM
Bluesir1
Mar 30, 2016 06:09 PM
dennisp
Mar 26, 2016 08:51 PM
