Odd Coolant loss
Old Dec 4, 2015
Moabrubi's Avatar
Moabrubi is an unknown quantity at this point
Odd Coolant loss
Hello everyone, Have an issue that's got me a bit stumped.
Short story is I was traveling down the freeway when my 98 DX started to overheat. Pulled over and no coolant in the overflow, there was coolant sprayed all over the back of the engine on the passenger side. I figured it was something simple like a busted hose or something but nope, everything is intact. I towed it home and refilled the cooling system and have driven the car 50 miles now and it's been fine.
Any ideas? I thought maybe it might be a head gasket but it shows no signs of that and I don't see why it would blow coolant out the back of the engine. I honestly have no idea where it came out from!
Thanks!
Old Dec 4, 2015
Wankenstein's Avatar
Re: Odd Coolant loss
Did you check the heater hose directly under the distributor for leaks?
Your car may or may not be fine: keep monitoring coolent level in radiator and reservoir for the next few days. If it's losing coolant in radiator and gaining coolant in reservoir..then most likely blown head gasket.
Is the radiator fan working properly?
Leaks near water pump? A partially failing waterpump may not leak but, may not spin properly and cause intermittent over-heating. Inspect radiator cap too (youtube vid).
Old Dec 5, 2015
Moabrubi's Avatar
Yes I checked all of the hoses. None are leaking.
Been driving the car around and no change in coolant level..
Fan works properly, comes on/off like normal. The only reason the car overheated in the first place was no coolant.
No leaks that I can see, water pump sounds probable and I was planning on replacing it with my timing belt change in a few thousand miles but as of right now it's working flawlessly.
I hate this car sometimes
Old Dec 5, 2015
mikey1's Avatar
it still could be,
its not overheating now because you just filled it up with coolant,
give it some time, the same thing might happen again
Old Dec 5, 2015
Moabrubi's Avatar
Originally Posted by mikey1
it still could be,
I'm failing to see how a head gasket could be an intermittent problem.
Old Dec 6, 2015
Might want to consider bumping up the timing belt, tensioner, waterpump change a bit sooner to rule out a possible failing water pump. If, the waterpump is the reason it overheated, you don't want to risk the possibilty of another overheating and possible head gasket replacement on your hands as well.
Old Dec 6, 2015
mikey1's Avatar
the blown head gasket is not intermittent, the symptoms of it are,
the overheating is a symptom of the blown head gasket, by filling up the coolant you are masking the problem, basically putting a band aid on it
Old Dec 6, 2015
Moabrubi's Avatar
I figured it out, looks just a heater hose. Found it leaking today, had a nice hole in it right on the clamp. Have no idea how it didn't leak significantly the past couple days as I was test driving it but I'll take it.
Old Dec 7, 2015
Which heater hose location?
herbiej
22
Aug 23, 2015 01:02 PM
civic98?
Aug 13, 2015 01:32 AM
Kyles24
Jul 16, 2015 10:14 PM
Hqly2001
General
Jul 8, 2015 04:07 PM
Bounddyy
Jul 8, 2015 11:22 AM
